Old 12-13-2024, 06:10 PM   #1
Kube
Super Moderator
Kube's Avatar
Default Re: 40 Ford radiator
Originally Posted by Mike E. View Post
I am restoring a forty ford that originally came with a V8 60 but the guy I bought it from replaced it with an 85 horsepower engine. My question is the radiator doesn’t look exactly like the ones I in the catalogs although it is split it doesn’t have the crank hole in it, and I wondering if mine is sized for the 60 and will it give me trouble with my mild flathead? He never finished the car so I couldn’t ask him how it worked. Thanks .
Mike, A photo would be wonderful so I can be certain.
To fit the 60HP radiator to the 85HP engine would be a lot of trouble. I'm not certain how that would work.
If you have a spilt core radiator the tin protective piece may be absent if there "is no crank hole in it".
Might be someone replaced the cores but didn't replace that tin.
The top tank should have 91A formed into it. Also, the filler cap should be off to the side, NOT on top / center.
The photos I have attached are what you should have with the 85HP engine.
Old 12-13-2024, 07:21 PM   #2
Mike E.
Kube
I will try to send this agin,there are two metal 1/8 inch strips welded to the frame horns where he moved the radiator forward.I will take a few pictures but I’m not sure I can figure out how to load them?
Mike E. is offline   Reply With Quote
Old 12-13-2024, 07:58 PM   #3
Kube
Super Moderator
Kube's Avatar
Kube
I think you need ten posts in order to attach a photo.
Once you have ten posts, go to the bottom of the box you are posting in... there is a place where it shows "additional options". Click on "manage attachments", Quite straight forward from there.
Does your radiator have the bottom outlets curved upward? Are they cast?
A 60HP radiator will have 022 stamped in the upper tank, typically on the left side of the upper tank.
