Old 11-05-2024, 12:56 PM   #1
FrankWest
FrankWest's Avatar
Default engine stalls when step on accelerator
1933 model B
Now that I finally got my car running again, idles fine, but engine stalls when step on accelerator. Could it be a fuel pump problem?
FrankWest is offline   Reply With Quote
Old 11-05-2024, 02:11 PM   #2
Charlie Stephens
Default Re: engine stalls when step on accelerator
I doubt it is the fuel pump because the carburator should be full of gas when you step on the accelerator. The stock carburetor doesn't have an accelerator pump so it is not that. My guess is that it is in the carburetor, can you borrow another one you know works? By the way you should add your general location to your profile.
Charlie Stephens
Old 11-05-2024, 02:15 PM   #3
35fordtn
35fordtn's Avatar
Do you have your mixture turned in too far on the choke cable. try turning it out a turn or so and see if it helps. I have seen bad condensors cause the same issue.
Old 11-05-2024, 02:24 PM   #4
Bob C
Have you tried turning the choke counter clockwise a little
to richen the mixture?
Never mind Michael beat me to it.
Old 11-06-2024, 03:13 AM   #5
FrankWest
FrankWest's Avatar
where is the adjustment on the choke cable?
Old 11-06-2024, 11:38 AM   #6
Bob C
Turn the knob that you use to pull the choke.
Old 11-06-2024, 03:59 PM   #7
FrankWest
FrankWest's Avatar
I never knew this had that function.
Note..I have a stromberg 35 carb.
Old 11-06-2024, 05:58 PM   #8
Bob C
Your carb doesn't look like this?
Old 11-06-2024, 07:21 PM   #9
FrankWest
FrankWest's Avatar
no, my carb is a stromberg 97 carb
Old 11-06-2024, 07:22 PM   #10
FrankWest
FrankWest's Avatar
stromberg 97 carb installed with downdraft attachment
Old 11-06-2024, 10:38 PM   #11
51504bat
51504bat's Avatar
Whole entire different animal. Look into the accelerator pump.
HOW TO: Install 9631K-97 Accelerator pump | Stromberg
Old 11-06-2024, 10:50 PM   #12
tubman
tubman's Avatar
Probably easier (and cheaper) to fix, though.
Old 11-06-2024, 11:06 PM   #13
Charlie Stephens
That changes the whole game. You carb should have an accelerator pump. With the car not running press on the gas and see if you get a squirt of gas into the engine. If you don't, that is probably your problem. Probably time to rebuild the carburetor.
Charllie Stephens
Old 11-06-2024, 11:35 PM   #14
cas3
send it to uncle max
Old 11-07-2024, 04:28 AM   #15
FrankWest
FrankWest's Avatar
how do I reach uncle max
Old 11-07-2024, 08:04 AM   #16
rockfla
rockfla's Avatar
IS it me OR I would like to see JUST how a Stromberg 97 is working on a 33 4cyl (Model B) from what should be an "updraft" single barrel carburetor, right?
Old 11-07-2024, 08:42 AM   #17
51504bat
51504bat's Avatar
https://www.snydersantiqueauto.com/p...9386&cat=41733
Old 11-07-2024, 08:44 AM   #18
51504bat
51504bat's Avatar
https://97-express.com/
Max Musgrove
[email protected]
435.322.0102
1173 South 1100 East
Salt Lake City, Utah
84105 U.S.A.
Old 11-07-2024, 08:58 AM   #19
51504bat
51504bat's Avatar
Just wondering, is a 97 carb a bit much for a stock 4 banger?
Old 11-07-2024, 10:11 AM   #20
Bored&Stroked
Bored&Stroked's Avatar
Lots of folks run either a Stromberg 97 or Holley 94 style carb - seems to work really well!
