#21 |
#22 | |
Much like Gene, I use my clutch HARD. Recently at TROG, I was starting out in 2nd. Rev'd the engine to about 3.5-4K and side stepped the clutch. This was in sand, but still no slipping or ill effects. Worked great. |
#23 | |
Seems like an OP here used the stock flywheel and used the Ford bolts |
#24 |
I bought a set of 7/16-20 7/8 thin head bolts. I will let the machine shop decide which fits best.
JB |
#25 | |
I’m actually friends with Michael Hays. I have a DF setup on my ‘66 Mustang race car. I got it the year those debuted at the SEMA show. From 1991-2020 I was in the aftermarket industry. I find the story about the weights on a DF pressure plate hitting a release bearing “interesting,” to say the least. I’d have been on the phone with Midway PDQ. Funny thing about these forums. You never know who’s on them, eh? Last edited by 1948F-1Pickup; 10-22-2024 at 07:45 PM. |
#26 | |
Upon tearing down, that's what he found. Obviously there was a failure somewhere. |
#27 |
Given the diameter of the standard 32 - 48 Ford throw-out bearing, it may have caught on those weights (that would not surprise me).
One has to be really careful when using these wide throw-out bearings on any diaphragm type clutch. I would surely check for any potential interference before an installation. Most of these pressure plates were surely NOT designed specifically for our Flathead Ford engines and associated parts! |
#28 | |
#29 |
Tim: Did he take any pictures of the issue? If so, I'd sure like to see them!
#30 |
I went through my parts stash and even though I have a nice core flywheel, nos ring gear, and a rebuilt original pressure plate I am going to run the Centerforce setup. The parts just look too nice to not. I tested a throw out on the pressure plate and it hits the fingers nicely. Hopefully it balances out well at the machine shop. Will keep everyone posted on the build
JB |
#31 |
#32 |
I removed the ring and weights from my Centerforce PP after they told me the weights were only needed for high power cars and were not needed with a flathead.
#33 | |
THEY being the Centerforce folks?
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#34 |
#35 |
I was told it would be fine to remove the weights over the phone from a CF tech.
The PP must fit other applications that would benefit from the weight Been running my CF diaphragm PP since 2019 without any issues. |
| Thread Tools | |
| Display Modes | |
