Old 10-20-2024, 07:44 PM   #3
JayJay
Default Re: Starter? Battery?
I think “nothing” is the key here. If the horn and lights work that means there is at least some charge. Trying to start even on a partially discharged battery, if the starter is good you should hear at the least a hum and a click as the Bendix tries to engage. Hearing “nothing” would indicate to me a starter, or maybe starter switch (although those are pretty simple and reliable, unlike a modern solenoid) issue.
Having said that, checking the battery as Gary suggests is a lot easier than pulling the starter motor. At least if the battery checks out OK then you will have eliminated a possibility.
Do check all the terminals - battery x 2, frame connection, starter switch connection. You may have a high resistance causing this. Low amps will flow but high amps won’t.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
