#21 |
That is the 39 Standard IMO.Had a couple over the yrs and had Whitney in Fullerton CA do the 12V conversion on them .
#22 |
Good info.
#23 |
It turns out that generator I showed a few days ago was a mix of parts, not a true '39 standard/pickup generator. It was not functional as it was. But I restored it into a fully functional, 2-brush with pulley mounted fan - very similar to the rare '39 standard generator. This uses the extra large bearing to carry the fan load, not the standard 2-brush bearing. I just had it running on the test bench this morning, putting out over 30 amps :-)
I'll be bringing it to Hershey in less than 2 weeks. It will be for sale on my table along with other restored generators. If you are there, stop by and say hi. South chocolate CJ 71-73. Steve |
#24 | |
#25 | |
While rebuilding or looking for a replacement, any way to improve these old systems would seem to be a benefit. |
#26 |
Gramps |
#27 |
#28 |
I agree to that.
But Ol' Ron is not wrong. It's 2024 now. I will try find a std 42 pulley, as I has a new idea on fan. |
#29 |
It’s not 2024 here. We are driving home from a swap meet with a truckload of 1932.
#30 |
Its 2024 nomatter, but no electric fan for me.
Question. So the pulley is from a older one whit now bigger holes made, or ? |
#31 | |
LR5003NPPU Track Roller Double Row Bearing 17x40x14 Sealed Track Bearings VXB Brand Last edited by big deuce; 02-07-2025 at 11:05 PM. |
#32 | |
As side note - In 1932-1937 generators I use a 5202-2RS double row angular contact bearing with custom machined inner and outer race spacer rings to make up the stack height difference. These modern sealed bearings are designed to take both radial and axial loads. |
#33 |
Ok, so there's the difference in the 38-39 front mount, they used a 47mm OD, and in '40
forward, they used the 40mm like mine. Thanks for the detailed post. |
#34 |
I've tried to follow, but what am I missing? Early generators that had the fan on the front used two small, Timken-style bearings and millions were made this way and used successfully in cars.
The move to removing the fan from the generator and then Ford went to using a sealed bearing in the two brush generators. So I understand, the two brush style can't handle a fan without upgrading the bearing in the front? Isn't a sealed roller "technically" stronger than a Timken-style bearing? |
#35 |
Is your motor hanging on the bell housing , hope the bell doesn't snap off, put a support to hold up front of motor.
#36 |
Yes, disaster waiting to happen
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#37 | |
I don't know all the answers, Ford had a bewildering variety of generators. It hurts my head to try to understand them. That being said, my understanding is that in 1938 they went to the large 6303 bearing in 3 brush and the soon to arrive 2 brush generators with fan mount pulleys. The 2 brush has a larger generator body, so there are different size front fork plates. The photo shows the larger 2 brush plate on the left, smaller 3 brush plate on the right. The other photos shows the bearings. On the bottom is the multi-part double roller bearing used 1932-1837, in the middle is the large 6303 bearing used in 1938-1939, at the top is the 6203 bearing used afterwards for non-fan mount pulley generators. There are many other variations. But this is a general overview. |
#38 |
Late great Bruce Lancaster said, " looking at the generator section in the green book will give you a headache. Good photos ndnchf, thanks
#39 | |
#40 |
Not left hand threads.
| Thread Tools | |
| Display Modes | |
