Old 08-28-2024, 06:25 PM   #1
fordfixer
Default AA transmission
Working with a museum in another state that is trying to put an AA trans. back together. Their question is how the rear bearing retainer parts are assembled.
Was wondering which way the inner plate is installed. Any pictures available?
Thanks for any help.
fordfixer is offline   Reply With Quote
Old 08-28-2024, 06:43 PM   #2
KMBeers
KMBeers's Avatar
Default Re: AA transmission
Glass beaded my motor mounts to get them ready for paint on my ‘29 Tudor. Still have 4 months to wait for my engine and trans to come back from the Rebuild Shop. Tomorrow I will be dropping off my radiator for a cleaning / repair / paint at the radiator shop.
KMBeers is offline   Reply With Quote
Old 08-28-2024, 06:49 PM   #3
fordfixer
I think you posted wrong.
Old 08-28-2024, 07:16 PM   #4
1955cj5
1955cj5's Avatar
Here are a couple of pictures that might be of use.....this transmission was in an A ccpu so the rear retainer has been altered, but it might give you a starting point
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-28-2024, 07:27 PM   #5
1955cj5
1955cj5's Avatar
You may find what you need here:
http://www.vanpeltsales.com/FH_web/f...ings_trans.htm
Old 08-29-2024, 07:17 AM   #6
john charlton
john charlton's Avatar
There are two styles of rear AA truck trans rear bearing retainer 4 speed . The most common is a pressed steel retainer which works with the muff coupling jack shaft . Later a bipartible U/J was used with a cast bearing retainer very similar to the 3 speed trans . With this setup you can change the clutch without Pulling the back axle back . It is easy to see which retainer they have ,
John in warm sunny Suffolk County England .
Old 08-29-2024, 09:07 AM   #7
fordfixer
How to post pictures here?
Old 08-29-2024, 09:20 AM   #8
1955cj5
1955cj5's Avatar
Look at post #6......hope it helps..
https://www.fordbarn.com/forum/showthread.php?t=301357
Old 08-29-2024, 09:25 AM   #9
katy
katy's Avatar
Click on "Go advanced", click on the paper clip icon.
Old 08-29-2024, 10:36 AM   #10
fordfixer
Hopefully these are the pics of the parts. Need correct sequence of parts.
Does this housing have grease zerk like the A? If not does it have a specific way to be mounted?
Old 08-29-2024, 10:41 AM   #11
Bob C
You only use one of those parts, depends on what coupling shaft you have. If you have a u-joint on the trans output you use the large bearing retainer. If you have the splined coupling shaft you use
the small stamped retainer.
File Type: jpeg 30-31_coupling_shaft_to_transmission_117.jpeg (28.0 KB, 12 views)
Old 08-29-2024, 10:47 AM   #12
1930artdeco
1930artdeco's Avatar
I have a 4 sp. at home I can take pics of when I get home.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
