Old 06-18-2024, 03:03 PM   #141
35fordtn
35fordtn's Avatar
Default Re: NEW products available thread
OldGold,
You continue to impress!!
Old 06-19-2024, 08:17 AM   #142
uncle buck
uncle buck's Avatar
Originally Posted by OldGold360 View Post
Hi David.
I did just finish up everything I needed to do to be able to accurately reproduce the ‘32 floorboards and I will always have them in stock, unless they stop making nice plywood.
Till then, here are some pictures of the ‘32 Floorboards.
Are these car or truck floorboards?
uncle buck is offline   Reply With Quote
Old 06-19-2024, 10:53 AM   #143
BoxCar Tom
BoxCar Tom's Avatar
Floor Boards look too good to cover up.
Pics of capped studs used with floor mats and clips used with carpets, found (purchased) on ebay 2008
BoxCar Tom is offline   Reply With Quote
Old 06-19-2024, 10:55 AM   #144
petehoovie
petehoovie's Avatar
Old 06-19-2024, 02:43 PM   #145
DavidG
DavidG's Avatar
Toml,
Gold in different forms.
Congratulation!
David
Old 06-20-2024, 02:43 PM   #146
OldGold360
Originally Posted by 35fordtn View Post
OldGold,
Thanks Michael!
OldGold360 is offline   Reply With Quote
Old 06-20-2024, 02:43 PM   #147
OldGold360
These are for cars.
Old 08-20-2024, 04:08 PM   #148
35fordtn
35fordtn's Avatar
The one year only 1932 Ford parking brake pawls (sector) is now available
https://thirdgenauto.com/product/193...ke-lever-pawl/
Old 10-11-2024, 10:30 AM   #149
OldGold360
I was asked if I could make some of the Ignition Lock Switch Cases for 38-39 Cars and 38-47 Pickups and Trucks, part number 81A-3712. These are made in small batches but at least they are now available to those needing this part.
https://nwclassicparts.com/products/...ck-switch-case
Old 10-14-2024, 10:11 PM   #150
Karl Wescott
Karl Wescott's Avatar
Default 1933-34 Cowl Light Grommets
It appears both Drake and Vintique have quit on this item... So my version, 3D printed in a flexible plastic.
Karl Wescott is offline   Reply With Quote
Old 10-15-2024, 05:33 AM   #151
DavidG
DavidG's Avatar
Karl,
Thanks!
Old 11-12-2024, 07:50 PM   #152
Karl Wescott
1935-36 Cabriolet top iron to body hinges. What I have photographed is a 3d plastic model as I will only be making these when I have a confirmed order. (I expect demand to be very underwhelming).
Karl
Old 11-19-2024, 03:10 PM   #153
OldGold360
Wiper/Hinge covers are now available for your 1937 Pickups and Trucks. I know several members here have inquired about the possibility of me making some. It’s been a long time coming. You can find them at www.nwclassicparts.com or reach out to me here via PM. Thanks!
Old 11-19-2024, 05:11 PM   #154
ford nut
ford nut's Avatar
great looking parts.
ford nut is offline   Reply With Quote
Old 11-21-2024, 06:04 PM   #155
OldGold360
Here’s one for you 38-39 Pickup and Truck owners. These are now available on the website.
https://nwclassicparts.com/products/...t-repair-panel
Old 02-16-2025, 10:28 PM   #156
Karl Wescott
1935-36 Phaeton top saddles.
Investment cast stainless. Unpolished for now, may offer polished later.
Old 02-16-2025, 10:30 PM   #157
petehoovie
petehoovie's Avatar
Old 04-04-2025, 10:18 PM   #158
Karl Wescott
Default Top Iron Wedgies 1937-39 (rumble) convertible/cabriolet
These are the "wedgies" that mount in the top irons at the upper rear corner of each window opening. Drake sells the pad that mounts into them. These are investment cast aluminum. I will be selling each, there are uppers/lowers/RH and LH.
Old 04-04-2025, 11:02 PM   #159
petehoovie
petehoovie's Avatar
Default Re: Top Iron Wedgies 1937-39 (rumble) convertible/cabriolet
Old 04-05-2025, 12:33 PM   #160
35fordtn
35fordtn's Avatar
Not a huge crowd of folks needing this but we now have 1932-33 Detroit Lubricator gasket sets.
https://thirdgenauto.com/product/193...-hardware-set/
