Old 08-18-2024, 12:27 PM   #1
ford38v8
ford38v8's Avatar
Default Re: 1950 ford custom/1990 ranger rear end install.
I'm confused. I was under the impression that the correct geometry dictated that angles should be equal, offsetting each other. Why would you settle for 2º to 3º for the pinion when the transmission is 4º ?
Alan
Old 08-18-2024, 01:52 PM   #2
ActionYobbo
ActionYobbo's Avatar
There is much more to working out pinion angle. You need to allow for wrap which depending on your HP and suspension setup will change the pinion a few degrees under full load or cause axle bounce
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 08-18-2024, 02:26 PM   #3
ford38v8
ford38v8's Avatar
Good point. Henry Ford solved that problem with a torque tube.
Alan
Old 08-18-2024, 05:00 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Henry solved a lot of problems with a torque tube!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 08-18-2024, 06:35 PM   #5
tubman
tubman's Avatar
Coop.
And caused a few as well.
Old 08-18-2024, 07:01 PM   #6
ford38v8
ford38v8's Avatar
I can’t think of one. Enumerate please?
Alan
Old 08-18-2024, 08:18 PM   #7
tubman
tubman's Avatar
Changing a broken axle, for starts.
