Finally good salt at Speedweek this year after the two previous years of rain and slush.
First run for our Rear Engine Modified Roadster running a supercharged stock block Ford flathead burning gasoline took place Saturday morning running against my current gas blown record of 205.744 I qualified at a speed of 215.473 MPH . The engine was not running perfectly experiencing a bit of a miss. Sunday mornings backup run was a complete failure the ignition issue being the cause the car only ran 187 so back to the pits to figure out what's going on. Checking timing we discovered what we thought was the problem. Put the car back in line and made another qualifying run the engine still had a miss fire but qualified over the record with a speed of 207.972. While we were working on the car in impound to get ready for Monday mornings backup run I decided to replace all of the electronic ignition parts out of the car. The ignition replacement was a simple dual point with condenser what I call good old 1980's analog stuff. On the back up run on Monday morning the engine pulled strong the speed was 215.668 the new record established 211.830. Now it was my sons turn to run for the fuel record which the team set in 2021 with Jeff Arnett driving Jeff earned his Red hat in the car setting the fuel blown record {but still burning gas}at 206.249. On the qualifying run Monday afternoon with a density altitude at 7770 feet the speed was 220.672 with an exit speed over 221 MPH oh I forgot to mention the temperature was 100 degrees outside every day. Tuesday mornings backup run the winds were blowing hard across the track. On the run the speed was 219.456 the new record established 218.240. Now it was time to change drivers this year a new driver on the salt Carly Moody. Carly has driven the car a number of times to speeds over 160 MPH in Maine at the LTA events previously but at Bonneville everyone is a rookie on their first runs ever on the salt. We worked to change the car so it would now be classified as a gas rear engine modified roadster. To do this we removed the blower and in its place installed a two deuce intake I fabricated. This intake and carb set up as well as the class change was going to be an experiment since we had never tried anything like this previously on the salt. To make a rookie run you can not exceed 150 MPH at mile 2 so Carly did her run perfectly running 137 MPH and deploying the chute as required. Carly was now qualified to run over 150 but not over 174 on her next pass. So back in line we go and this time Carly was now able to run the car to the third mile the current record was just over 140. On the run the speed was 157.616 back to impound. We now prepared the car for the backup run which Carly made latter in the afternoon. On this run the speed was 159.918. The temp out side on that run was 101.7 degrees with a density altitude 7796 feet the now new record is 158.767. All three records were set with the car driving off the line under its own power no push starts. Speedweek 2024 was huge success for the entire team. Did I mention it was HOT! This stock block Ford flathead engine to date has run well over 60 miles on the salt many runs well over 200 MPH as they say in the movies she's a keeper Clark. ![]() Click on the link below here's a great video of Carly's back up run. Turn up the volume here the Ford flathead make music sit back and enjoy the ride. ![]() https://www.youtube.com/watch?v=EpL-DhsQi64&t=203s
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 Last edited by Ronnieroadster; 08-11-2024 at 09:32 PM. |
Great post Ronnie! Thanks for that, and congrats to you and your team on the return of good salt!
Alan |
That was great! Congratulations on all of your accomplishments! How long was the course this year? It looked like it went on for mile and miles. The ride looked smoother than some I've seen.
Congrats for the great results ! Awesome ride. What trans are you running this year ?
Impressive results, congratulations.
Congratulations on having a great time as well as setting new records!
Thanks that was a FUN and EXCITING ride. Congrad's for great run.
That was really cool, congratulations on your records and to Carly's !!! do you have a video of your run?
Wow, congratulations. That is great news, Ronnie! Thanks for posting and I'm glad this year was a success for everyone involved.
Fantastic Ronnie. Congratulations to you and your team. A huge achievement and reward for all the hard work.
Ronnie
Just "WOW" |
#13 |
Outstanding! Congratulations!
#14 |
Congratulations
#15 |
CONGRATULATIONS RONNIE ! ! ! !
Paul |
#16 |
Wow! That was exciting and fabulous performance. Thanks and congratulations to you, Carly and all you team for keeping flatheads on the cutting edge of record breaking speed.
A great video. |
#17 |
Good job and great visiting with you as always, Ronnie. I made a few passes in the 180s with a best of 184. I was hoping for more. Somebody was supposed the bring me some gear sets but it didn't happen. I still had a great time. 184 ain't bad for an unblown Flathead on gas. Looking forward to World Finals.
Wayno
Life is not a spectator sport. |
#18 |
Congratulations Ron !!
#19 |
Congrats Ronnie and crew - fantastic results!
#20 |
Ronne, Congratulations to you and your team. You impress me with your know-how, and your determination.
| Thread Tools | |
| Display Modes | |
