Old 08-01-2024, 09:05 AM   #1
Andy
Default Re: Gas leaking from both carbs
Do you know that 97’s will run just fine with whole tops removed. You can pull the tops off and see the fuel level with the car running.
I would check to see if the fuel inlet valves are good. I hold the carbs upside down and blow in the inlet. There must be no leakage.
The float level is adjusted by bending the tang on the float.
Are these the Speedway carbs?
Andy is online now   Reply With Quote
