Re: Anyone with experiences working with Gocat speed shop?
I was told to re post this
At present I'm trying t build a street engine that will have adequate power, good fuel economy , at a reasonable cost. Unfortunately, the engine is not acceptable in most places because it has no "speed equipment" or fancy "stuff? amd looks like a stock engine,
Actually, it really is quite stock. I've eliminated all the stuff that can cause trouble away from home. like fuel pump, generator, early water pups and fan./ Engine should produce 20/30 ft/lbs of torqur between 2/3000 rpm, 20 + MPG and cost aprox 3K$. Run 50 75K miles before rebuild with proper maintained.
Another problem, finding all the right stock parts needed.. All you need is parts that have a long life. the only mod id highr compression, and that's not as easy as you think!!!
Gramps. What do you thing the stock compressiom of a flathead is????
Gramps
