Old 05-31-2024, 10:58 PM   #1
36coupe
36coupe's Avatar
Default 3-3/8” tach for 36 5w
I am looking for suggestions on what tachometer will work in place of the radio/ashtray on a 36 5w.
I am running a crab distributor, mild 255.
I would to buy a new tachometer. S&W?
I started looking at what is available and figure it would be easier to ask what i should use.
3500? Hal efffect?
36coupe is offline   Reply With Quote
Old 06-01-2024, 07:07 AM   #2
36coupe
36coupe's Avatar
Default Re: 3-3/8” tach for 36 5w
Any suggestions?
Old 06-01-2024, 07:22 AM   #3
Jumbogem29
I use the SW wings in my 51 Mercury had it converted over to 6V i have more info if need thanks
Jumbogem29 is offline   Reply With Quote
Old 06-01-2024, 07:27 AM   #4
Jumbogem29
Oh yea by the way i bought a column mount new a guy was making on the hamb for it 3 3/8 for a 2 1/8 column that was in my Mercury or they make some nice aluminum ones for your column size as well.
Old 06-04-2024, 01:26 AM   #5
OHV DeLuxe
A friend did this.
OHV DeLuxe is offline   Reply With Quote
Old 06-04-2024, 07:20 AM   #6
36coupe
36coupe's Avatar
Originally Posted by OHV DeLuxe View Post
A friend did this.
That’s exactly what I want to do.
A plain steward and warner modern tach for a 12v flathead with a crab distributor
I guess 3500 max rpm is sufficient for a flathead?
Old 06-04-2024, 10:55 AM   #7
petehoovie
petehoovie's Avatar
A friend did this.
Old 11-09-2025, 10:56 AM   #8
kingeak
kingeak's Avatar
Curious if you ended up installing your tach and where you ended up installing it (radio spot or ?)
What tach did you end up going with?
Eric
1937 Ford Standard
1953 Mercury Monterey
1963 Chevrolet Corvette SWC
1963 Chevrolet Impala (409 ci / 425 hp) = giddy up
2023 Chevrolet Corvette HTC
kingeak is offline   Reply With Quote
