#21 |
#22 |
#23 | |
But, you'll have to bore out the first two cam bearing bores and use some big bearings. ![]() You may also need a girdle . . . and a blower . . . and a hat injector! LOL Then, a custom 4.375 stroke billet crank and a set of Carillo rods . . . Now we're talking! I'm just trying to spend all your money from afar! LOL |
#24 |
You guys are going way over board. Don't need any where's near all that stuff to make HP and a lotta speed
Under 300 inches can be very powerful even with gasoline ![]() Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#25 |
Ronnieroadster as I said I purchased this engine from a Bonneville racer in LA. 25+ years ago when shipping was cheaper. An interesting old gem that I owe it to it to get her back running. Has. C4 trans I believe I will switch it back to a flywheel. No idea what I may do with it when running.
| Thread Tools | |
| Display Modes | |
