Old 05-21-2024, 05:07 PM   #1
KiWinUS
KiWinUS's Avatar
Default Re: 13/4 intake
I have an old Bonneville engine I have owned for over 25 years with the most amazing port job ever. It has 1.800 intake valves and 1.700 exhaust. 3.375 x 4.250. Had a Potvin Eliminator cam. I may have to dig it out and resurrect this gem. Unfortunately I don’t know whose car. Block has 4 sleeves so could tell some stories. Both valve seats ground into block.
Old 05-22-2024, 08:45 AM   #2
old Tom
what is the CI of that motor?
old Tom is offline   Reply With Quote
Old 05-22-2024, 09:14 AM   #3
KiWinUS
KiWinUS's Avatar
304ci.
Old 05-22-2024, 09:14 AM   #4
KiWinUS
KiWinUS's Avatar
304 cubic inches
Old 05-22-2024, 09:36 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
Come on Tony . . . bring the ole' girl back to life! Now, with a bigger cam in it (like a .500+ lift roller), it could be something.
But, you'll have to bore out the first two cam bearing bores and use some big bearings.
You may also need a girdle . . . and a blower . . . and a hat injector! LOL
Then, a custom 4.375 stroke billet crank and a set of Carillo rods . . .
Now we're talking!
I'm just trying to spend all your money from afar! LOL
Old 05-22-2024, 02:10 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
You guys are going way over board. Don't need any where's near all that stuff to make HP and a lotta speed Under 300 inches can be very powerful even with gasoline
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 05-22-2024, 04:46 PM   #7
KiWinUS
KiWinUS's Avatar
Ronnieroadster
Ronnieroadster as I said I purchased this engine from a Bonneville racer in LA. 25+ years ago when shipping was cheaper. An interesting old gem that I owe it to it to get her back running. Has. C4 trans I believe I will switch it back to a flywheel. No idea what I may do with it when running.
