#221 |
#222 | |
If you missed my thread on this, it's here : https://www.fordbarn.com/forum/showt...light=speedway. |
#223 |
#224 |
Dang, you made my morning! As fate would have it, I have two lock plates here. Maybe I can find tabs that haven't been used yet. Or maybe treat the metal with heat like annealing or something. I know little of such things.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#225 |
On my pump test stand, I have a valve to shut off flow and test relief valve pressure. I restrict the flow to 40 psi back pressure and check flow rate. Typically 1.5 gpm.
#226 |
#227 |
Heck, that might work! The pump on my grinder works . . . otherwise, I'd be tempted to try it as well.
#228 |
Dale, the reason I'd use the worst one is that the oil must become quite laden with grit from the stones. I have taken the bottom plates off the 5 pumps and graded them with a 1 through 5 star rating for wear on the plate. Least wear is the one I tried yesterday with the correct pickup for my truck pan. I gave that a 5, along with another. There's a 4 and two 3s. Two issues are the one marked 'melling M-19' has a stripped hole at pickup tube flange and one of the 5 short body pumps has straight cut gears instead of bevel, making it sort of a mongrel..I went through my pipe fittings and came up with the needed parts for a 'Flatjack style' of tester.
#229 |
My tester worked well and I found some variations among the pumps as expected. Two of the bevel gear pumps showed 57 with valve closed, one showed 63 and another 75. The two best ones (both original ford)showed 40 with valve fully open which is a through a 3/16" orafice. The melling had an angled wear pattern on it's base plate. Any wear on ford plates was flat, but the pumps with wear on the plates clearly showed worse in the open valve position. The melling also dropped of considerably in the open position. The winner at 75/40 is that first one I tried, but the drive gear shows movement on the pin. I have driven out that pin and will be a tomorrow project as dinner was ready. I think cas3's flipping the plate idea would be quite beneficial and I forgot to mention the straight gear version of the short pump only pumped to 50 lbs closed valve and about 20 open. Had a lot of interuptions today. Maybe tomorrow I can do some flow tests. Edit: These tests were performed with hydraulic fluid in the warm sun, about 75 today. I would guess the hydraulic fluid seemed consistent with motor oil at operating temperature.
#230 | |
#231 |
Thanks for illustrating all this Pete!
#232 |
With my oil pump choice taken care of I turned my attention to some cast iron. It's been a very beautiful, warm and sunny 3 day weekend, and the foyota's tailgate has been the best workbench one could ever hope for.
#233 | |
#234 |
I'm suspicious that someone shimmed the relief valve spring in the pump you got 75 psi from. You don't need more pressure than the factory 57 +/- setting.
If you have a truly flat surface (in the machinist sense) you can lap the worn bottom plates. Set a piece of wet/dry sand paper on top of the flat surface, add some water, and polish the plate in a figure 8 pattern. The old favorite for a flat surface was a piece of ground plate glass, you had to be careful not to drop anything near it. The intake and heads are looking nice and clean. Highly recommend using an old head gasket and tin foil (or modeling clay, your pick) to check clearances in the combustion chamber, then surfacing the heads to achieve 0.050 +/- clearance above the pistons. I had a nice looking set of EAB heads to put on dad's engine, one turned out to be warped significantly but cleaned up well with surfacing. |
#235 | |
Hoping to get big bore head gaskets and some other parts ordered today. I have found the hydraulic fluid to be a powerful solvent, and after sitting overnight the 75 lb pump is showing 57, which I attribute to gummed up relief valve. I retested the two best with a different bucket with a wood platform inside to hold things steady. The 63 remained so and with the pump stabilized in the bucket it was much easier to view the gauge. With this more controled testing, I found that the one with 57 read at 45 lbs with the valve fully open. That one became my pick.
#236 |
If you have one of those profile checking/transferring tools that is a bunch of hard wires that slide in a flat central sleeve, they are really handy for checking how a piston fits in a cylinder head dome. Rough, but handy reference data. Also, remember that as the heads are milled the dome decreases in diameter and may get close to the pistons around the perimeter depending on how far down the pistons are at TDC.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#237 |
That's kinda scary, Terry. With the extra compression will I need to run premium gass?
#238 |
You'll not have too much compression - just make sure you have enough piston to head clearance (squish).
You want about .040 to .045 with the gasket in place (above the piston). As long as you have that amount (and hopefully not much more), then your engine will run great. Flatheads like a tight quench/squish area. |
#239 |
I don't have a profile gauge. Does foil or clay work on pistons? And this test is done with a used head gasket and light torque?
#240 |
Any sort of cheap modeling clay works fine --> just make a couple 1/4" round "snakes" and place two of them on a piston crown (or in the chamber) -- one horizontally and one vertically. Putting a bit of WD40 on the crown and the head helps to make it not stick.
Obviously, you first want to ensure the piston is at TDC. Use an old head gasket and just cinch the heads down by hand (don't need to torque them down). Then carefully pull the head and use an XActo knife or razor blade to cut 1/2 of the clay way on each snake. Then, use a mic to measure the thickness. Depending on your brand of piston and head chamber shape, you may find more clearance in the center of the head-chamber than towards the sides. You need a minimum of .040 over the WHOLE crown of the piston. On my engines, I make sure I'm at .040 - and if I have to mill the head to get that number, then that is what I'll do. Having a tight quench really helps the performance of any flathead. Here is an example - Navarro heads and Ross (consistent radius dome) pistons: 2015-07-17 17.59.50 copy.jpg 2015-07-17 18.15.18 copy.jpg Last edited by Bored&Stroked; 05-13-2024 at 05:04 PM. |
| Thread Tools | |
| Display Modes | |
