Old 06-23-2011, 04:01 PM   #1
RockHillWill
RockHillWill's Avatar
Default Stewart Warner Armature Threads
Can some one tell me what the thread size is on a Stewart Warner horn armature ?
I am quite certain that it is left hand treads, but I cannot measure the diameter or threads on the broken one that I have.
I appreciate any information.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 06-23-2011, 06:12 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Stewart Warner Armature Threads
Will, ...I totally forgot about that I was supposed to send you a couple of horns. If you recall, I told you that I needed you to send me an e-mail to remind me!! I leave in the morning for San Diego. I can send you a S/W horn or two when I get back if you still need them by then.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-23-2011, 06:41 PM   #3
RockHillWill
You're right, I forgot as well. I may have to learn to fix this issue. So far, I have heard of over 38 SW horns w/ broken armatures.
Old 06-24-2011, 09:46 AM   #4
Bruce Lancaster
I believe that MSC industrial sells a range of LH taps and also taps in the odd thread sizes that appear some places on old Fords.
Old 06-24-2011, 11:01 AM   #5
d.j. moordigian
d.j. moordigian's Avatar
Bruce,
I believe Will is looking for a die, which MSC should have as well.
Dudley
d.j. moordigian is offline   Reply With Quote
Old 06-28-2011, 01:09 PM   #6
28 Special Coupe
28 Special Coupe's Avatar
Make it 39! I found out that they were left hand threads after I broke mine. I had to glue the ratchet wheel on with JB Weld. It worked for a while until the windings started shorting out due to age.
28 Special Coupe is offline   Reply With Quote
Old 06-29-2011, 05:52 AM   #7
RockHillWill
This seems to be a prevalent problem, so I guess I better try to figure a way to repair mine. Replacements are VERY hard to find and folks are quite proud of them if they have one.
So far I have identified the threads (thanks Don), acquired a tap and a die, ordered #8-32 left hand threaded rod from McMaster-Carr and have ordered the #27 (.144") tap drill.
I have been able to cut off the broken remains of the original threads and have cut a flat surface and cut in a 'starter drill' and am waiting for the tap drill to get here.
It is my intentions to tap a left hand thread, insert a piece of the threaded rod and loctite it in place.
Old 06-29-2011, 11:59 AM   #8
28 Special Coupe
Sounds like a great plan. Unfortunately that exceeds my skill set. Please let us know how it turns out.
