#161 | |
#162 |
Thank you once again Pete. The bottom photo shows a couple more parts I picked up from my friend that sold me his father in law's block collection. He had mentioned he had some more bellhousings and oil pans for me in an old airstream on his property. All those good blocks and so many parts 1 1/2 miles down the road, and up until seven or eight years ago I knew nothing of them.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#163 | |
It amazes me how many good flathead parts (and trucks!) you have on your island.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#164 | |
That Airstream might be worth more than the flathead stuff that's in it to the summer people on the island
#165 |
I'm no expert on the 8ba for sure, but I know I installed one in my '47 2 ton in 2014. I don't recall anything tricky or unusual. But wait, I may have used the forward set of crossmember holes for the radiator and support that Ford put in there for the longer 6cyl G engine (or perhaps a future 8ba).
#166 |
#167 | |
#168 |
I have had a lot of flathead era ford trucks but the vast majority got here the hard way. My first flat V8 came from the island. Once the hook was set, I had haul them from the mainland. Oregon, Eastern Washington, Parker's Praire Minnesota, Montana, N Dakota etc. Here's my first, that '38 tonner before and after. Most of the blocks came all at once, but I collected plenty of them the hard way too.
#169 | |
#170 |
Quick-Draw McPete
#171 |
#172 |
It'll buff out. That must be why it was suggested I hit those areas with some fine emery. Consider it done. Here's some of what got done yesterday. I'll shoot for getting the crank in today. The pump on the far left had the golden pickup to center on the truck pan. I also want to look at my distributor options. I know I have at least one aluminum one and one cast iron. Can someone elaborate on the photo of all the timing covers, for instance which distributor works with which cover? Thanks.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 05-05-2024 at 07:57 AM. |
#173 |
The distributor on the right works with cover "A", the left fits B,C,and D.
#174 |
While I agree with Dale that the piloted distributors are probably more stable and therefore better, I have never had a problem with hem not fitting. And I have swapped a lot of distributors on a lot of 8BA' over the last 60 years. I never knew there was a difference until about 5 years ago and now believe they should match.
#175 | |
#176 |
Well it turns out I have 3 timing covers and none of them are the piloted type. I also have 3 distributors. An aluminum piloted one and 2 cast iron with no pilot. One of the cast iron ones is really clean and feels nice and tight. As far as cam end play, I tried my chosen timing cover both with and without a gasket. I cannot get my dial indicator endo on the back because of the stand and couldn't find a way to set it up inside. For now I can say that you can see and hear it move just a bit with no gasket and with the gasket it seems like a lot. My thought is move it back and measure with plastigage. I installed the crank just before I came in for lunch. Snugged down the six bolts and it feels so nice turning with a wrench. Haven't torqued yet. If I was a fishing guy I'm thinking this is fishing for blue marlin in the Bahamas. (without all that awful sun blasting in your eyes).
#177 |
Is it piston time or am I missing something?
#178 |
Sure sounds like piston time.
If you can hear and feel the cam end play without a gasket then that's the way I'd do it for sure. The nice unpiloted distributor sounds like my first choice, and the nice iron cover of course. Might check ring end gaps just to be sure all is correct there.
#179 | |
On the crank, still just snugged down as I wanted to make sure split lockwashers are good and 60,80,100 ft.lbs sequence. The crank shows .003 endplay. With all schooling on the 8ba, I found some really good parts today. Maybe best is a perfect, rebuilt model 94 1 1/16" version. The bores look so much larger side by side with a 15/16". I will pull it apart for deep inspection and a fresh kit. I hadn't realized the 94 came in different sizes.The other thing I found mixed in a full 3lb coffee can of 5/16" bolts was four what must be the special cam gear bolts. I cleaned one up. Short on threads, but a deep shoulder. Been a great day in the engine shop.
#180 |
Gary, I always enjoy your threads. Especially this one since I have an 8RT that runs but really needs a rebuild. This is a great reference and I love the bonus items in the background of your pics.
An old bike, a CANNON and a big two blade prop for ?? You have some cool stuff in your collection. Scott |
| Thread Tools | |
| Display Modes | |
