Old 05-02-2024, 11:47 PM   #4
stingywrap
Default Re: NGK Anti - Seize?
Thread Coating: Modern spark plugs often come with a special plating or coating on the threads designed to provide corrosion resistance and ensure proper torque. Applying anti-seize compound can interfere with this coating and alter the torque values, potentially leading to over-tightening or under-tightening of the spark plugs.
Heat Dissipation: Anti-seize compounds are typically greasy or oily substances, which can act as insulators. When spark plugs are installed with anti-seize, it may interfere with the heat dissipation from the spark plug threads to the cylinder head. This can potentially lead to overheating of the spark plug and affect its performance.
stingywrap is offline   Reply With Quote
