#21 | |
I do have an untouched composite on standby just in case its another problem entirely .Drove the car for 30 years ran 180 max until pssenger side spiked. Found all kinds of crap stuck in the block at the rear water jacket. |
#22 |
Yes, very common and you got to get that out for sure.
#23 |
Since you found the crap at the rear of the block that's an example of lack of proper coolant flow. Another reason I always open up the coolant holes in head gaskets especially at the lower rear of the block. And between the cylinders at the lower edge of the deck as well.
I'm only 71 years old but still thinking about how to improve the Ford flathead so we can enjoy them well into this 21st century. ![]() Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
| Thread Tools | |
| Display Modes | |
