Old 04-28-2024, 05:39 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default 8BA Bell housing
When using the 8BA truck bell housing with the large round bolt circle for the transmission does it matter weather or not if you use the stamped steel Mercury bell housing as long as you use the correct starter plate ? I don’t work on very many 8BA engines. Thanks
Old 04-28-2024, 05:44 PM   #2
deuce5wndw
deuce5wndw's Avatar
Default Re: 8BA Bell housing
The starter plate from the Mercury will fit the cast truck housing the difference being the truck is recessed for the dicast seal that bolts on the last two oil pan bolts. If you don't use the seal it will fit fine.
deuce5wndw is online now   Reply With Quote
Old 04-28-2024, 05:54 PM   #3
Ken/Alabama
So, to go the other way using the Mercury bell housing I can use the truck starter plate and use the seal . I have both starter plates but only have a Mercury bell housing.
Old 04-28-2024, 11:31 PM   #4
deuce5wndw
deuce5wndw's Avatar
Ken I have never tried that combination but I see no reason it shouldn't work.
Old 04-29-2024, 08:52 AM   #5
pistonbroke
Ken, I believe that's what I'm running in my 41 pickup and it works fine. Tim
Old 04-29-2024, 09:02 AM   #6
Tim Ayers
I do believe the only difference is the cast iron truck one will take a 11" clutch and the stamped steel Mercury can only fit an 10" or smaller.
Old 04-29-2024, 10:06 AM   #7
Ol' Ron
Ol' Ron's Avatar
using the stamp steel passenger bell housing you can bore the register to fit the T-170 trans and weld on some ears and have the best transmission ever made.
Graps
Old 04-29-2024, 03:56 PM   #8
alanwoodieman
Graps? why not Gramps
Old 04-30-2024, 03:03 PM   #9
Steve/IL
Steve/IL's Avatar
The T-170 is a Tremac 4 speed trans. 4th is overdrive. Mid to late 80s F150. 3 different OD ratios. Get one from a V8. Top Load Shifter comes out approximately 2" from an original 3 speed. Lots of posts on Ford Barn. Got one in my Avatar 35 Roadster.
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 05-01-2024, 10:20 AM   #10
Ol' Ron
Ol' Ron's Avatar
My stupid factor waz very high that day, sometims it craps!!
G
