Old 04-25-2024, 06:44 AM   #1
rockfla
rockfla's Avatar
Default Does this look to be enough clearance? OR too much?
Modifying an oil pickup tube for an early oil pan. I put a straight edge across the pan and measured to the bottom. I made a little go/no go gauge (if you will) and here is where I marked the oil pickup. Before I TIG it, any concerns or adjustments any can see I should make???? I have the bail holding the screen on the pick up just about touching the bottom of the pan?
Old 04-25-2024, 06:54 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Does this look to be enough clearance? OR too much?
Looks about right to me . . . I like the screen to be about 3/16 to 1/4" off the bottom of the pan.
Old 04-25-2024, 06:59 AM   #3
rockfla
rockfla's Avatar
I have a 1/4" block of aluminum bar, I call lay that on top of the screen and double check it tonight before I TIG it!!! Right now, IF i get it any closer my bail will hit the bottom of the pan.....OF course this is all measured without any gasket
Thanks B'd&S'd
Old 04-25-2024, 07:29 AM   #4
Mart
Mart's Avatar
Looks good to me. I do it the other way around. I made a piece of plate that represents the bit of block where the oil pump fits and bolt it and the pump to the oil pan. Then you can also check baffle clearances etc.
Old 04-25-2024, 07:32 AM   #5
rockfla
rockfla's Avatar
That is my next hurdle, Mart. I got to clearance the baffle SO timely and good info on that aspect. Thank you Sir!!!!
Hey Mart, do you have a picture of yours you could share???
Old 04-25-2024, 10:52 AM   #6
petehoovie
petehoovie's Avatar
Old 04-25-2024, 04:29 PM   #7
Mart
Mart's Avatar
You can see it in this video.
https://youtu.be/aWLIYLaOXts?t=1401
Hope it helps!
Old 04-25-2024, 04:53 PM   #8
KiWinUS
KiWinUS's Avatar
Don’t shoot me just yet but I put Chevy pickup on if I’m modifying one. Much nicer traps oil better actual pickup tube is now down closer to bottom. 1/4” clearance is my number. Midget racers used them.
Old 04-26-2024, 05:33 AM   #9
Lawrie
Lawrie's Avatar
Kiwi
You got any details on the chev pickup to use
Thanks Lawrie
Old 04-26-2024, 02:32 PM   #10
Ken/Alabama
Ken/Alabama's Avatar
Here’s the issue I see with the new pickup tubes.
Old 04-26-2024, 02:35 PM   #11
petehoovie
petehoovie's Avatar
Old 04-26-2024, 02:36 PM   #12
rockfla
rockfla's Avatar
Thanks for that visual, I can fix that too, now that I know!!!!! I've got extra tube... I'll post pictures when I am done!!!!
Old 04-26-2024, 02:43 PM   #13
rockfla
rockfla's Avatar
Hope it helps!
Tremendously!!! Thank you Mart
Old 05-01-2024, 11:21 AM   #14
rockfla
rockfla's Avatar
Here is the mod on the oil pick-up tube and thanks to Ken in Alabama the "extention" of the tube itself!!!!
Old 05-01-2024, 11:24 AM   #15
petehoovie
petehoovie's Avatar
Old 05-01-2024, 11:43 AM   #16
rockfla
rockfla's Avatar
Thank you Pete, great work as always!!!!
Old 05-01-2024, 12:05 PM   #17
Mart
Mart's Avatar
Just a hunch but if it were me I would take all the paint off it. If that paint breaks up or goes soft it will end up in the lubrication system.
Old 05-03-2024, 07:50 PM   #18
panic
I prefer 3/8" minimum screen to floor
panic is offline   Reply With Quote
