Old 03-27-2024, 04:34 PM   #1
31deluxe
Default Just bought a 31 roadster- Questions 1 at a time
Picked up this 31 Roadster just before the winter and have not had much time in the New York unheated garage to play around.
Do you think I need a new wiring harness or just a little electrical tape.
Someone did a nice job of brazing the fan. Can you see it?
Seriously. Reading a lot of posts on how to upgrade headlight wiring using bullet connectors.
I will be using bullet ends on headlight bulb socket end and from new headlight wiring harness.
If the spring connectors are removed or not used on the bucket side where the conduit connects to the bucket. What puts tension on the conduit connector to hold it it place? Seems that the dimple on the conduit ferrule would not be enough to hold it in place.
31deluxe is offline   Reply With Quote
Old 03-27-2024, 04:44 PM   #2
mhsprecher
mhsprecher's Avatar
Default Re: Just bought a 31 roadster- Questions 1 at a time
Roadsters are great.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 03-27-2024, 04:59 PM   #3
Jim M
Jim M's Avatar
I have a 29 Roadster that is absolutely wonderful. EVERYONE wants a ride in the rumble seat. You are going to have a ball. This blog is absolutely SOOOO friendly.
Jim M is offline   Reply With Quote
Old 03-27-2024, 06:45 PM   #4
stickshift
stickshift's Avatar
That fan can be "wall art" . Please don't try to use it, Snyders has new ones that won't come apart and damage the radiator or hood, or a person. There's visible rust under the paint.
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 03-27-2024, 07:04 PM   #5
oldspert
oldspert's Avatar
Unless you want to chance ruining a radiator and/or hood. You better replace that fan.
Ed
oldspert is offline   Reply With Quote
Old 03-27-2024, 07:28 PM   #6
Bob C
You can make a one blade fan out of it. The fan and wiring need to go in the trash.
Old 03-27-2024, 08:22 PM   #7
Synchro909
Synchro909's Avatar
Ditto the above re ditch that fan. It WILL fail and the consequences could be fatal
I reserve judgement on the wiring without being able to see it in person.
BTW, Nice car!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 03-27-2024, 08:25 PM   #8
31deluxe
The fan is already gone as is the wiring harness. Trying to get a picture of how bullet connectors are used.
Old 03-27-2024, 10:20 PM   #9
CT Jack
CT Jack's Avatar
I also vote for sending the harness and fan to the trash. Anyone who is riding around with an "original" 2 bladed fan is playing with a diaster waiting to happen.
CT Jack is offline   Reply With Quote
Old 03-27-2024, 10:25 PM   #10
ModelA29
ModelA29's Avatar
Buy a new harness and anything else you need. Chasing electrical problems on the side of the road isn't fun. Make sure you get the harness with the correct contacts for the headlights. Some companies use the wrong ones.
https://www.snydersantiqueauto.com/p...d=976261&cat=0
ModelA29 is offline   Reply With Quote
Old 03-28-2024, 06:48 AM   #11
nkaminar
nkaminar's Avatar
Congratulations on your new car. It is a beauty. And welcome to the Barn. May the Fordce be with you.
Old 03-28-2024, 07:45 AM   #12
old31
I like the Brattons harness over Snyders. Brattons has all connectors soldered.
old31 is offline   Reply With Quote
Old 03-28-2024, 08:36 AM   #13
Canton_Model_A's
Canton_Model_A's's Avatar
BTW, Nice car!
At the 'Old Car Festival' at the Henry Ford Museum last year, the guy next to me had his fan let loose on his CCPU. the carnage on the hood was to say the least bad, blade went thru it and landed like 10 feet from the car. I agree, that brazed fan should be 'Wall-Art'
Dave
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 03-28-2024, 11:44 AM   #14
katy
katy's Avatar
Originally Posted by nkaminar View Post
Congratulations on you new car. It is a beauty. And welcome to the Barn. May the Fordce be with you.
Ditto
Old 03-28-2024, 06:00 PM   #15
mngrant
One additional purchase, Model A Mechanic Handbook by Les Andrews.
At 78 yrs, I don’t trust my memory. So this handbook continues to assist me with my fourth A. Which is a 1930 Roadster.
mngrant is offline   Reply With Quote
Old 03-28-2024, 08:05 PM   #16
updraught
updraught's Avatar
Good combo.
The fan should kill the rats next time they chew on the wiring.
updraught is offline   Reply With Quote
Old 03-29-2024, 11:30 AM   #17
gdmn852
gdmn852's Avatar
Hello, definitely get rid of the fan , I had one break on a 30 Roadster, ruined hood side panel and radiator. Congratulations on the roadster, odd how the lower price roadsters have more demand now than originally higher price sedans. Looks like your car is Washington And Riviera Blue?
gdmn852 is offline   Reply With Quote
Old 03-30-2024, 12:22 PM   #18
dmar836
It's already GONE he said!! Wow.
dmar836 is offline   Reply With Quote
Old 03-31-2024, 06:45 AM   #19
nkaminar
nkaminar's Avatar
"It's already GONE he said!! Wow."
Fan tastic.
Old 03-31-2024, 03:11 PM   #20
Wick
Wick's Avatar
Replace the wiring harness, it's easy. Make sure the battery cable is for 6 volt not 12v and your ground is clean. The wiring behind the dash is very important, I usually find a mess of bare wires that will cause problems.
Headlights when not working right, 99% of the time is a bad ground at the housing.
Wick is offline   Reply With Quote
