Picked up this 31 Roadster just before the winter and have not had much time in the New York unheated garage to play around.
Do you think I need a new wiring harness or just a little electrical tape. Someone did a nice job of brazing the fan. Can you see it? Seriously. Reading a lot of posts on how to upgrade headlight wiring using bullet connectors. I will be using bullet ends on headlight bulb socket end and from new headlight wiring harness. If the spring connectors are removed or not used on the bucket side where the conduit connects to the bucket. What puts tension on the conduit connector to hold it it place? Seems that the dimple on the conduit ferrule would not be enough to hold it in place. |
Roadsters are great.
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
I have a 29 Roadster that is absolutely wonderful. EVERYONE wants a ride in the rumble seat. You are going to have a ball. This blog is absolutely SOOOO friendly.
That fan can be "wall art" . Please don't try to use it, Snyders has new ones that won't come apart and damage the radiator or hood, or a person. There's visible rust under the paint.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
Unless you want to chance ruining a radiator and/or hood. You better replace that fan.
Ed |
Ditto the above re ditch that fan. It WILL fail and the consequences could be fatal
I reserve judgement on the wiring without being able to see it in person. BTW, Nice car!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
The fan is already gone as is the wiring harness. Trying to get a picture of how bullet connectors are used.
I also vote for sending the harness and fan to the trash. Anyone who is riding around with an "original" 2 bladed fan is playing with a diaster waiting to happen.
Buy a new harness and anything else you need. Chasing electrical problems on the side of the road isn't fun. Make sure you get the harness with the correct contacts for the headlights. Some companies use the wrong ones.
https://www.snydersantiqueauto.com/p...d=976261&cat=0 |
Congratulations on your new car. It is a beauty. And welcome to the Barn. May the Fordce be with you.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 03-29-2024 at 06:16 AM. |
I like the Brattons harness over Snyders. Brattons has all connectors soldered.
#13 | |
Dave
--------------------------------------- 1929 Model A Tudor - "Darla" '29 Model A: Old enough to start with a crank, young enough to steal the show! "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
#14 |
Ditto
#15 |
One additional purchase, Model A Mechanic Handbook by Les Andrews.
At 78 yrs, I don’t trust my memory. So this handbook continues to assist me with my fourth A. Which is a 1930 Roadster. |
#16 |
Good combo.
The fan should kill the rats next time they chew on the wiring. |
#17 |
Hello, definitely get rid of the fan , I had one break on a 30 Roadster, ruined hood side panel and radiator. Congratulations on the roadster, odd how the lower price roadsters have more demand now than originally higher price sedans. Looks like your car is Washington And Riviera Blue?
#18 |
It's already GONE he said!! Wow.
#19 |
"It's already GONE he said!! Wow."
Fan tastic.
#20 |
Replace the wiring harness, it's easy. Make sure the battery cable is for 6 volt not 12v and your ground is clean. The wiring behind the dash is very important, I usually find a mess of bare wires that will cause problems.
Headlights when not working right, 99% of the time is a bad ground at the housing. |
| Thread Tools | |
| Display Modes | |
