Old 03-20-2024, 10:15 PM   #21
jeepguy1948
Default Re: Final Drive ratio, will a 3.25/1 be too steep ??
He say’s very clearly that he “has a chance to buy (cheap)” no need to ask why because he tells us.
jeepguy1948 is offline   Reply With Quote
Old 03-21-2024, 09:04 AM   #22
deuce_roadster
deuce_roadster's Avatar
You probably can use that setup as long as you stay in Iowa!
Old 03-21-2024, 09:18 AM   #23
sidevalve8ba
sidevalve8ba's Avatar
So, according to those gear ratios, you have a T-5 out of a Ford product, not an S-10. Am i correct?
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 03-21-2024, 10:13 AM   #24
bschulze
Trans #1352-192 The web site says it is out of: GM 1989 S-Truck 2.8L V6 Only
bschulze is offline   Reply With Quote
Old 03-21-2024, 10:31 AM   #25
sidevalve8ba
Yep, you are correct. Ford also used those same ratios in some offerings. Usually 4 cylinder stuff.
Old 03-21-2024, 01:14 PM   #26
V8COOPMAN
V8COOPMAN's Avatar
The idea here is to get a trans with WHATEVER gear ratios you want, and then to swap the "S-10" tail shaft housing and short shift rod from an S-10 to move the shifter forward. It all bolts together! Only thing to consider is to make sure BOTH transmissions are either WC, or NWC (matching each other).
Coop
Click Links Below __
T5 W/TORQUE TUBE
