Old 03-17-2024, 09:42 PM   #1
PaddyR
Default Choke rod
The choke rod through the grommet on the dash is so tight that the return
spring can barely pull the choke rod back. Any suggestions? Thanks.
PaddyR is offline   Reply With Quote
Old 03-17-2024, 09:58 PM   #2
mcgarrett
Default Re: Choke rod
Shoot the rubber grommet with silicone spray lube or WD40. If that doesn't help, replace it.
Old 03-18-2024, 05:24 AM   #3
nkaminar
nkaminar's Avatar
Rubber can be machined (drilled or reamed) when frozen in liquid nitrogen. Maybe dry ice would work.
Old 03-18-2024, 10:10 AM   #4
Banditorama
Check to see if there's corrosion on the rod where it slides through the grommet.
Banditorama is offline   Reply With Quote
Old 03-18-2024, 10:14 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
Open the hole in the grommet with a sharp drill or a rat tail file.
Bob Bidonde
Old 03-18-2024, 11:22 AM   #6
MilwaukeeMike
MilwaukeeMike's Avatar
Ream it carefully. These cars shake and a snug fit helps hold the needle setting.
MilwaukeeMike is offline   Reply With Quote
Old 03-18-2024, 06:04 PM   #7
brito36
Reproductions are of a softer type rubber compared to the original grommets.
brito36 is offline   Reply With Quote
Old 03-18-2024, 07:08 PM   #8
al's28/33
al's28/33's Avatar
make sure the rod itself is straight and true. Also confirm the arm linkage on the carburetor is not gummied up either.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-18-2024, 08:51 PM   #9
Wick
Wick's Avatar
Polish the rod where it goes through the rubber with 0000 steel wool. A little wax helps afterwards.
Last resort, drill the rubber out a little. Lately I've found the replacement grommets to be too tight.
Wick is offline   Reply With Quote
Old 03-19-2024, 09:58 AM   #10
PaddyR
Thanks to all who responded to my question. The replacement grommets are way too tight to allow the rod to return to closed position. Problem solved.
Old 03-19-2024, 10:45 AM   #11
burner31
burner31's Avatar
Have you looked at your motor mounts?
A bad/broken/cracked/bent motor mount will do it.
Keith
Shawnee OK
'31 SW 160-B
