Old 03-10-2024, 07:19 PM   #1
Tim Ayers
Default Source for gear shift knob threaded insert/reducer
In this age of Google, I can't believe I'm having such trouble finding a two way threaded insert to put a glass knob on an emergency brake extension.
I need one that is 5/8" 18 pitch OD and 5/16" 24 pitch ID. I've tried so many search word combos, but all that comes up are metric pieces.
Does anyone have a source for these?
Thanks,
Tim
Old 03-10-2024, 07:25 PM   #2
woodiewagon46
Default Re: Source for gear shift knob threaded insert/reducer
Why don't you take a 5/8"x18 bolt and slice off a piece and drill and tap it for 5/16"x24?
woodiewagon46 is offline   Reply With Quote
Old 03-10-2024, 07:47 PM   #3
Tim Ayers
I guess I could do that. Never thought to do it that way, but that's for the suggestion.
Old 03-10-2024, 08:02 PM   #4
farmertom
farmertom's Avatar
Tim,speeddawg.com or speed dawg shift knobs. iv'e recently replaced the original brown v8 ebossed shift knob in my '37 fordor cause the original knob way to small for my hand and dont car for shape of it either. imo the price was right i believe all the choices have a same size insert and you specify which insert you need.also geta washer which i did not use and a jam nut. Tom.
farmertom is offline   Reply With Quote
Old 03-10-2024, 08:12 PM   #5
farmertom
farmertom's Avatar
Tim,speedawg.com or speedawg shift knobs.all knobs come with a common threaded insert permanately installed and you coose the adapter size you need i too chose the 5/16"x24 for my '37. orig brown v8 embossed was way to small for my hand and didnt care for shape either Tom.
Old 03-11-2024, 02:05 AM   #6
deuce lover
deuce lover's Avatar
X 2 which is what I did yrs ago.
Old 03-11-2024, 07:25 AM   #7
Automotive Stud
Automotive Stud's Avatar
I've had good luck putting a helicoil in the shift knob also.
Automotive Stud is offline   Reply With Quote
Old 03-11-2024, 07:56 AM   #8
Tim Ayers
Thanks for all the suggestions. Hard to believe this is such a difficult item to source. I seem to recall these were fairly common items.
Old 03-11-2024, 08:07 AM   #9
62pan
There on Ebay. Search, brass shift knob insert. Can get six different styles and metric or 5/8.
62pan is online now   Reply With Quote
Old 03-11-2024, 08:08 AM   #10
jimTN
For some reason the knob peddlers all want to force the use of communist threads!
Old 03-11-2024, 08:12 AM   #11
Tim Ayers
Hahahaha!
Old 03-13-2024, 07:45 AM   #12
av8coupe
I have gotten this type of insert at Fastenal (sp?). I don't remember the exact dimensions I used buy they had a selection to choose from.
av8coupe is offline   Reply With Quote
Old 03-13-2024, 08:02 AM   #13
Tim Ayers
Found one on Ebay. For the $10, it wasn't worth my time to make it at this point. Maybe when I retire I'll make a run of them.
Old 03-13-2024, 08:43 PM   #14
Pete
Make them out of titanium, they will shift faster.
Old 03-14-2024, 04:13 AM   #15
Tim Ayers
Ah, true. But what will it do for my gas mileage?
Old 03-14-2024, 09:01 AM   #16
1948F-1Pickup
1948F-1Pickup's Avatar
First part I ever made on a lathe was an insert to put a larger thread shift knob onto a Hurst shifter…..
1948F-1Pickup is offline   Reply With Quote
Old 03-14-2024, 09:22 AM   #17
GB SISSON
GB SISSON's Avatar
IIRC, JC Whitney's shift knob bushing increased your mileage by 15%. Not sure if anybody elses's version topped that, but it's unlikely.....
Old 03-14-2024, 11:09 AM   #18
Tim Ayers
Yep. I bucked up an extra $0.75 for the turbine edition.
Old 03-14-2024, 12:46 PM   #19
B-O-B
B-O-B's Avatar
Plate it & make it even faster!
B-O-B is offline   Reply With Quote
Old 03-14-2024, 04:13 PM   #20
FlatheadTed
FlatheadTed's Avatar
Put some grease on the thread of shift leaver,then fill the knob with JB weld and bingo .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
