I have several questions on how this conversion done properly I am looking at a car to buy with this conversion I understand they are changing the starter motor but I wonder about horns guages blower motor overdrive controls etc.the lights are easy change the bulbs I wish they the seller had left the 6 volt system alone would appreciate input on what to look for if go ahead with a purchase Thanks Ford barners
Take a look at this video and then call the company with your specific questions.
https://www.bing.com/videos/rivervie...9620&FORM=VIRE The other option is to wait until the seller successfully, neatly and completely makes the 12V conversion and then you buy it as a fully working vehicle. That way you're not buying into a "project" you don't need. |
I found this book helpful. Section on OD transmission, List bulb conversions. Simple and Short.
I had a '53 that was converted to 12V. The horns need no change. The gauges can be made to work with voltage reducers. The blower motor can be replaced with a 12V one or you can have it rewound at a electric motor rebuilding shop. I didn't have overdrive, so i'm not sure on that part
I just completed the conversion on my '51 Tudor. For the overdrive I purchased 12 volt relay and solenoid. What has been said about the other things is correct.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
I could go on here and replace to trans to T170 and a8" ford rear This way you can use the original wheels and nobody will know Probably good for 110K with just general maintenance. |
#7 | |
Like Ol Ron said the starter is one thing you don't have to change. I ran a six volt starter in my 55 bird for five years with no issues. Tim
Thanks Ford Barners for all the input on a 12v converted system I wonder how to obtain the book spoken by two you I would like to buy the 53 but I have a small slag the man I first spoke too on buying the car has since passed away so know I have to deal with a mechanic representing the family and the car is multiple states away the car has had several improvments which keeps my interest
Ran a 12 vt conversion on my "52 F1 for over ten years. Had the bendix break on the 6vt starter but it was the old one that came with the truck when it was new. A voltage drop on the gauges and all good to go. Chap
#12 | |
#13 |
thanks for the info on 12volt conversion book I have one ordered am sure I will do a conversion down the road even if the car I am bird dogging doesnt work out
#14 |
There's a volt drop on the back of the early Mustang gauge panel that I have used for the volt drop for the gauges. It can be found on e-Bay or at some auto parts stores. The Motorcraft part # is GR-508. It's called an instrument cluster voltage regulator. Many of them listed on e-Bay for $25-$30.
#15 |
I added a 1 ohm ignition coil resistor in series with the original 6v solenoid to ease the stress on the starter button. You could convert to a 12v solenoid but the contacts may not the extra (2x) starting current long term
#16 |
Assuming the original 6V starter is still there
| Thread Tools | |
| Display Modes | |
