well this has been educational as usual, I will backup and review the leak issue with dual systems to get a better understanding of the situation. With that said however, growing up on a farm with old grain trucks, it was not that unusual to have to pump your breaks up at times because the brake shoes probably needed adjusted, with those old trucks. would you be able to do that with a leak situation on a dual system? The second observation is this: A leak on a single cylinder system would appear to be just as chaotic because if it leaks off, you have zero brakes, or at least brakes that will disappear each time you pump it until the fluid reserve is empty, at which time the need of the emergency brake as stated by someone is a helpful item. Am I missing something here? I changed to a dual M/C because I wasn't happy with front drum brakes and changed over to the consistency of disc brakes. I think I would probably have liked to have a better understanding of the calculations involved before choosing a M/C . I may look for a M/C with a bigger bore. I have good brakes now, but I would like to have the pedal a little higher, now I understand the issue better, I think I can resolve it. LOL
#2 | |
Ron ...... Just about the time you begin thinking that you understand the issue(s) better, you might want to re-think it all once again. Brakes is one very deep subject. You mention possibly looking for a M/C with a bigger bore. You must remember that increasing the diameter of the M/C bore will directly affect how much pressure that you need to push the brake pedal. Increasing the M/C bore will INCREASE the amount of foot pressure necessary to produce the same stopping power as before the change. You will likely be surprised at how much increased foot pressure will be required. Just one of the laws of hydraulics. Coop . |
| Thread Tools | |
| Display Modes | |
