Is there somewhere around the northern Indiana area that anyone knows of that will grind or have a L100 camshaft?
get a hold of pete on here. BUT idk if you can message him with only 1 post. welcome to the barn.
I have a one for an 8BA in Granger. PM me if interested. Thanks.
Bob Update-the cam has sold, but have many other flathead parts for sale. Last edited by V8 Bob; 02-12-2024 at 03:02 PM. |
@KiwiTony (member here) is/was the person grinding these cams. Hopefully he'll pop on to this thread.
I was probably one of the persons that introduced the cam to the Barn, During the late 80;s & 90's I installed them in most of my builds. The main reason was the "SOUND", and properly tuned it preformed quit well. Unfortunately, many people don't have the knowledge or equipment to properly tune a Flathead. The can has 245 degrees of intake duration, which means that a 9:1 compression engine has only 6:1 at low and medium RPM Thes ran poorly at best in a small displacement endgame, especially in a heavy car.Originaly the cam from my shop cost 125$ lifters 45$ 16 1.5 Chevy valves 50$ Today you can't do that Ina 280/300 ci inch engine, it works just fine However in a "STREET" engine a Max 1 would provide more torque and you don't need all the other stuff. When making a modification to any engine. The application is the important issue/ Esticits adds no power are economy to any engine. The Barn should help newcomers make good decisions.
Gramps |
Tony was in NZ on vacation, but he is definitely your man to grind an L100 cam.
The 400jr is a great cam for racing, it was my go to cam untill the D410 came out. For a street engine the L-100 has a kinder profile and can be run with less valve spring pressure 55/60 and still turn 5k. Price here isn't an issue as both are alittle expensive. Too bad JWL's dyno isn't in operation we could test allot of OLD cams. I just found a Howards M-8 in my stash (NEW) interesting lobe. They were popular back in the 50;s/60's
Gramps/ |
H&H will grind a L100 but by the time I get a core to them and all that shipping crap not worth it. I tryed to get a hold of BoB but was unsuccessful. And they see where he has sold the cam. I’ll find one or find something to grind one. I have lots of cores
I wonder who grinds them for Mike??? 😁
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
deleted
#13 |
Old post, but I saw Brother's Custom posted that the Bean Bandits Bonneville car went 140+ using one of Tony's L100's. Kudos Tony for keeping this cam in circulation. I've got two in the shop that will be going in future build projects.
#14 |
I've got one too that is just going in a build
#15 |
#16 |
looking forward to it
#17 |
Support the barn and buy quality. KiWinUS has known quality cams. Tony is great to deal with.
#18 |
KiWinUS ground a stock 8ba cam to L100B specs for my blower motor and I think it runs perfect!
#19 |
I have one for sale for an early engine with a press on cam gear that I'm not going to use. I'm in PA.
What does just the grinding cost these days? |
#20 |
Is KiWinUS still grinding L100s ?
Anybody knows ? |
| Thread Tools | |
| Display Modes | |
