Any locksmiths on the forum? I have a 1954 Customline that I need the ignition switch changed to fit my key. Thanks.
Butch |
A local locksmith should be able to help you. I had a local locksmith do key work on my 56 Bird.
Called every locksmith in my area. They concentrate in reprograming FOB's, unlockong doors and residential stuff. Each one said this is too old for them to fool with.
So key fits doors but not ignition?
I would first get new ignition key set if you need to keep it a running driver.
As far as rekeying, it seems to be a lost art. Basically you need to find locksmith that specializes in this sort of thing, it will be pricey. essentially on the tumbler there is a little steel cover, it holds down the pins and about 6 springs. each pin as an upper an a lower. the correspond to the position, if they are match correctly to your key, once the key is in, you unlock it. I have to do this same thing because I want 1 key for the lock and ignition, but someone broke the ignition on F100. At some point someone did the old stick a screwdriver and broke out all the pins. but my replacement obviously key doens't work my old keys and I also want mine to match up. I reached out to a lock parts guy on ebay to see what diameter these are https://www.ebay.com/itm/325205509361 you can see all the parts are there, you just have to be crafty in taking part your tumbler and matching your key. Also guys as easy as this seems, it has become a very lost art to do. A locksmiths in LA are just key cutters like hte OP says. I once was quoted 100's to rekey a Cadillac lock. On those they just pull a number and cut a key for 35.00. I can imagine what actual rekey pin work would cost. Also there is a locksmith on ebay that sells refurbished car lock sets with new keys, I'll see if I can find them. here they are, maybe do a contact seller https://www.ebay.com/sch/i.html?_ssn....m3561.l161211 Last edited by Abe Lugo; 02-06-2024 at 10:15 PM. |
This shop made keys for my trunk and ignition. https://www.beltonlocksmith254.com/
'54 Skyliner. As close to original as I could restore it to. |
I can re pin and cut keys for most Ford locks up to 1964.
Contact me after April 1st and I should be able to help. 845 551 5132 Phil
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
The right hand door lock cylinder has the key code stamped on it. It should be the same for the ignition cylinder unless it was changed out in it's previous life.
Bill, certified Ford nut. 2024 F-150 2018 Lincoln MKZ 2016 Focus 1961 Comet S-22 1956 Ford Crown Victoria 36 Chevy, 351C/FMX, 8", Mustang II |
Thanks everybody. I'll contact 32phil. Hopefully he can help.
Another person you can contact is FlatheadCoupe (aka John Mclure), he may be able to help sooner than April 1st.
Abe Lugo, Thanks for the ebay links. My drivers door lock broke last week in my 54. I was able to order door lock assemblies and ignition cylinder keyed the same.
| Thread Tools | |
| Display Modes | |
