Old 01-23-2024, 08:11 PM   #21
paul2748
paul2748's Avatar
Default Re: Best chemicals/solutions/goops to clean off gear oil, etc. on a chassis
In my opinion, just a rag will wipe up any grease/oil on a car that I presume was painted two years ago. That is what I use on my 56 Bird undercarriage and most of it comes off.. Any thing harder to get off i use Super Clean.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-23-2024, 10:30 PM   #22
fordor41
fordor41's Avatar
I use low odor mineral spitits. spray it on and let it sit and scrape
fordor41 is offline   Reply With Quote
Old 01-24-2024, 04:33 PM   #23
Detonator
Detonator's Avatar
I'm a Simple Green fan, too, but whatever you choose, buy one of those small, cheap plastic kiddie pools to slide under your work area.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 01-24-2024, 08:29 PM   #24
3twinridges
3twinridges's Avatar
My go to degreaser is a commercial citrus degreaser called de-zov all. It’s expensive, but works. The others I have tried just move it around. Spray, let soak, then hit with a good low pressure power washer.
JB
3twinridges is offline   Reply With Quote
Old 01-25-2024, 08:52 AM   #25
Tim Ayers
Great idea!
Old 01-25-2024, 08:05 PM   #26
paul2748
paul2748's Avatar
Doesn't mineral spirits eat the paint ??
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-25-2024, 11:18 PM   #27
fordor41
fordor41's Avatar
I've never had any problems with damaged paint even with Rustoleum that was on our '41 frame. used to wipe it down with mineral spirits occasionally with no effect
Old 01-26-2024, 10:29 AM   #28
TJ
TJ's Avatar
I've used it on occasion and it does not harm the paint.
Old 02-13-2024, 11:55 AM   #29
Fred A
Fred A's Avatar
I find myself using 91% alcohol on tools that are not plated. Degreasing with alcohol gets into the cracks while prepping for Zero Rust. The finish is smoother and leaves some rust protection after a light oil film. My CHANNELLOCKs are presentation grade. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 02-13-2024, 01:19 PM   #30
jplutz
jplutz's Avatar
Tim, I agree with McGarrett, AVOID OVEN CLEANER!! I use it to remove paint!!
I build models and when I get someone else's "glue bomb" , I spray it with EasyOff to remove the paint and I use it to correct my own mistakes. It will not hurt plastic or pot metal and it has no effect on some acrylics(pre-painted models..? don't know why). JPL
jplutz is offline   Reply With Quote
