Old 12-31-2023, 09:21 PM   #11
1942deluxe
1942deluxe's Avatar
Default Re: 47 V8 ignition mystery
Craig, you'll need the 21A distributor cap and rotor along with plug wires. Looks like Third Gen has all of that in stock. Not sure if the 46-48 spark plug conduits will work either. You may have to route the wires another way or modify the conduits if you elect that route as a permanent solution. Believe the 42 wires are color coded. The clips would be shorter too, Michael may have them also.
