Old 12-28-2023, 12:22 AM   #11
47topless
47topless's Avatar
Default Re: 47 V8 ignition mystery
In my '47, I was having trouble making a good connection of the rotor to the cap. The gasket you are referring to, between the cap and distributor body, was in bad shape. It caused the cap to sit ever so slightly off on the body. I ordered a new one but, while I waited for it to arrive, I just removed the old gasket, reinstalled the cap and it solved the problem. I understand that the gasket is only there to keep water from getting in the distributor. I believe that now.
Phil
47topless is offline   Reply With Quote
