Old 12-06-2023, 10:51 PM   #1
svmsr1044
Default 56 Ford wheel size
What is the width of a 56 Ford Fairlane Sunliner OEM wheel? What is a good source for the purchase of a new OEM quality wheel for my 56?
Thanks,
Steve
svmsr1044 is offline   Reply With Quote
Old 12-07-2023, 12:41 AM   #2
51504bat
51504bat's Avatar
Default Re: 56 Ford wheel size
Not sure of the wheel width but this site shows tire size as 6.70x15
http://www.classiccardatabase.com/sp...56&model=26409
Wheel Smith in Corona, CA might offer OEM style wheels.
Classic Car Wheels Made To Order | (thewheelsmith.net)
Old 12-07-2023, 09:28 AM   #3
KULTULZ
KULTULZ's Avatar
Arrow Re: 56 Ford wheel size
The actual wheel size is 15" x 5.0"
You should easily find take-offs on FleaBay.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 12-07-2023, 08:30 PM   #4
Grumpy Rick
I got new tires for my '56 Fairlane Vickie a few days ago, and had them measure the wheels. Mine are 5" for sure.
Grumpy Rick is offline   Reply With Quote
Old 12-07-2023, 09:05 PM   #5
miker98038
miker98038's Avatar
Having been down this road, a couple things to watch for. These early wheels had a smaller opening in the center. Most later Ford wheel fit, but they have the larger opening. Secondly, the “humps” around the center or the outer rim have to be correct to mount the oem hub cap (dog dish) or the full wheel cover. So lot of rims that fit may or may not end up working for you.
Years ago WheelSmith made me a set of oem centers on 7” rims with 4” backspacing. It let me mount 10” cheater slicks on the back of the bird and run 55-56 (color difference) dog dishes. But that’s another story.
miker98038 is offline   Reply With Quote
Old 12-08-2023, 12:18 AM   #6
KULTULZ
KULTULZ's Avatar
10-4 ON THIS!
The MPC shows service replacement wheels as a 1960 PN.
You would most likely need a HOLLANDERS PN to find a correct wheel unless you know exactly what you are looking for.
Old 12-08-2023, 04:12 PM   #7
Gene F
Gene F's Avatar
Super expensive back then?
Old 12-08-2023, 08:42 PM   #8
miker98038
miker98038's Avatar
Pretty reasonable as I recall, but it’s been over 15 years. He had a couple stock wheels for the centers, I don’t know what the rims were. But I didn’t have full wheel covers so it didn’t matter. Otherwise I’d have had to ship the centers to him.
Old 11-01-2024, 05:15 PM   #9
mrmoose
mrmoose's Avatar
Howdy. I have a couple old wheels, 15x5 and 15x5 1/2 with 4.5" bolt pattern. The center (hub) hole on one is 2.25" and the other is 2.5". I don't want to pull a wheel to fir if I don't need to...going to use the correct one for a spare. Any idea the correct hub hole size for '56 Club Sedan? Thanks very much.
mrmoose is offline   Reply With Quote
Old 11-01-2024, 09:21 PM   #10
miker98038
miker98038's Avatar
You should be able to get close enough just popping a hub cap. A 1/4” difference is tape measure work, not a micrometer. I’m guessing the 5” rim is the 2.25. But there might have been some early wheels (station wagons, police cars, etc) with the smaller center and a 5 1/2” rim.
Old 11-01-2024, 10:11 PM   #11
Jwawhite
Jwawhite's Avatar
Old tires vs New tires
Sidewalls we’re not balloonish then, essentially flat faced from rim to ground.yes the tread width is the same but:
I have a modern day tire/spare in the rear compartment of my wagon. The tire wall will not allow the door cover to close completely. I don’t like this and have tried to find a reasonably priced tire.
Jwawhite is offline   Reply With Quote
