Old 11-22-2023, 10:08 AM   #1
larry harding
Default speedster project... need help
i've been working on a speedster project for about a year now. it is along the lines of the rootlieb kit some of the suppliers carry. there is a green one on youtube that i'm trying to copy with a few of my own ideas. the rootlieb kit sits the firewall back 4-5" more than normal a" set up. my problem is the throttle ain't going to work out this way. if i just extend the throttle link i'm going to have a really long travel on the foot feed. have any of you guys built the rootlieb kit? i would appreciate any pictures or advice you can offer, thanks
larry harding is offline   Reply With Quote
Old 11-22-2023, 11:32 AM   #2
Jim Brierley
Default Re: speedster project... need help
I don't have a pic, but on my green speedster I bought a 'spoon' throttle from Speedway Motors in Lincoln NE. It bolts to the firewall. I'm running Stromberg downdrafts, and I positioned the throttle to line up with the cab bases.
Old 11-22-2023, 12:57 PM   #3
larry harding
that's an idea, but what i can see in the videos on yt they are running the stock throttle pedal. i want to go that rout if i can figure ouy the linkage.
Old 11-22-2023, 02:17 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Larry, you are making that WAY to difficult. Use tubing to space the Throttle Assy. back to the firewall.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-23-2023, 07:58 AM   #5
larry harding
that is an idea i had.. i would have to lengthen the rod between the carb and the rocker assembly. hopefully a better suggestion will come along.
Old 11-23-2023, 10:07 AM   #6
BRENT in 10-uh-C
Larry, because the firewall is in a new location, if you are still wanting a mechanical linkage system you will either need to lengthen the control rod between the bellcrank and throttle control assy arm, -or you must lengthen the throttle peg on the control assembly like in the pictures below. I have done it both ways on my cars and can tell you that I much prefer moving the entire Control Assy. rearward instead of adding to the throttle peg. Not sure how much 'better' (-i.e.: simple) it could be. From my vantage point, it will be much simpler than trying to McGuyver a motorcycle clutch cable assy to use as a throttle.
BRENT in 10-uh-C
Old 11-23-2023, 12:06 PM   #7
Big hammer
How about placing the body forward ( the 4-5 inches) , with the body back it looks like the footwell is tighter ? Also with the body forward the pedals would work better? Just a different way to look at the issues
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 11-23-2023, 12:23 PM   #8
johnneilson
Moving the body rearward will increase the f/r bias for better traction
Just saying, J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 11-23-2023, 03:44 PM   #9
BRENT in 10-uh-C
Actually, I think it feels, -and looks proportionately better when the body is more rearward.
To make the controls work with the body moved rearward, I just heated the pedals and bent them backwards slightly just above the pedal shaft which made the pedal stand more vertical. Then where the pedal bends rearward about 120° at the top, that area is bent where the bend is about 90° which makes the pedal position(s) about horizontal as they come out of the floorboard. Moving the body rearward basically moves the shift lever forward in the cockpit giving more room in front of the seats too.
On my cars, I also moved the steering column rearward by drilling new holes in the frame rail just in front of the rear engine mounts. On my Mobilgas car, I believe I used a '32 Drag Link because I had fabbed a longer Pitman Arm to get faster/quicker steering when I was racing the car.
File Type: jpg MobilGas Steering Column Location01.jpg (82.5 KB, 41 views)
BRENT in 10-uh-C
Old 11-23-2023, 06:17 PM   #10
larry harding
i think i'm on my way with the spacers. i had started thinking that way when i saw your post. i bought a couple of fabricated pieces from rootlieb and am fabricating everything else my self. i talked to a guy at rootlieb who got me moving everyhing rearward 4-5"
the steerng box is right against the left motor mount. i've made a spacer to lenghthen the starter button next will be the rod from the carb to the rocker. your speedster looks great, i hope mine will look that good. did you make your own headers and intake? where are in east tenn? i've been going to the east tenn. crank up in unicoi 30+ years.
Old 11-24-2023, 10:53 AM   #11
BRENT in 10-uh-C
Yes, it seems each one of my speedsters had a different exhaust system.
My shop is less than 15 miles away from Jeff's place on Scioto Rd. For years, I played with engines & tractors, and was very active in the Crank-up and in the ET Antique Engine Club. Just not enough weekends to play with all of our toys. Plan on coming by the shop for a visit next June when you are in town.
BRENT in 10-uh-C
Old 11-24-2023, 01:33 PM   #12
larry harding
i've probably been by your place several times. started going to etcu back in the 80's, too bad we lost jeff(geoff?) last year. i'm also into cushman scooters and one day of the ride from erwin, we've ridden thru scotia rd several times. if i make it up to etcu next year i definitley would like to see your toys. between antique and modern two wheelers, flywheel engines and model as i've got too many hobbies, but love them all. i enjoy meetinf other gearheads.
Old 11-24-2023, 03:29 PM   #13
divcoone
divcoone's Avatar
I’m also playing with a Rootlieb speedster build. I like the throttle ser up. Did you bend your pedals yet?
Bob Giles
Johnstown, Pa.
divcoone is offline   Reply With Quote
Old 11-25-2023, 05:18 PM   #14
larry harding
yes.... heated them right in place down near the shaft and bent them back, then heated the elbow area and leveled them up. a friend who has a speedster (rootlieb kit i think) sent me pictures of his pedals holding a ruler next to the pedals. about 8" from the fire wall. i've spaced my throttle rocker back 4" i'm making a new crossshaft from one the old throttle/ spark levers i replaced. it's going to take a bit of tinkering and bending to get the throttle working smooth. i don't know yet what i'm going to do to extend then link between the carb and rocker. the link is not a standerd diameter so threading an extension is not practical. hate to loose the nice plating on the link.
Old 11-26-2023, 04:14 PM   #15
divcoone
divcoone's Avatar
Thanks for the information.
