Old 11-20-2023, 07:45 AM   #1
Bryan Markell
Default Model A engine wiring
Need correct spark plug and coil wiring for a Model A engine, may I ask who might currently be the supplier?
Bryan Markell is offline   Reply With Quote
Old 11-20-2023, 08:51 AM   #2
J Beard
Default Re: Model A engine wiring
I have used Brattons for over 30 years. For many of their parts they have options and will state which is correct and what is a modern option.
J Beard is offline   Reply With Quote
Old 11-20-2023, 08:58 AM   #3
Joe K
Joe K's Avatar
The spark plug are the copper or brass "jumpers" that go between the nubs on the distributor cap and the screw top on the spark plug. Any jumper will work but earlier cars were one pattern, later cars another.
The "hot" wire between coil and distributor top is available from suppliers. Originally without "hoods" or caps, many users put a modern rubber hood to "seal" the connection against entrant water.
Otherwise, coil wiring would be part of the "harness" which most every Model A supplier will sell you. And this would be separate from the headlight wiring which is sold frequently with the "switch plate" - and have quality issues all their own.
Wiring diagram with correct wire colors below.
https://lesmodela.files.wordpress.co...ng-diagram.pdf
Sources of repop Model A parts with online catalogs below (Google search terms)
Tams Model A
Snyders Antique Auto
Brattons Antique Auto
Berts Model A
There are others.
Joe K
Shudda kept the horse.
Old 11-20-2023, 12:20 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bryan, before we go too far, ....define 'correct' as it pertains to your question. The two reproduction items that you are asking about are not "authentically correct" in all details as compared to original OE supplied pieces if that is your goal. It is the length on the spark plug wires, and the sheath on the coil wire that is the differences.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-20-2023, 01:20 PM   #5
Bryan Markell
Thank you for the responses. With your help the question has been satisfied.
Old 11-20-2023, 08:22 PM   #6
nkaminar
nkaminar's Avatar
I saw a photo of a Model A where barbed wire was used between the nubs on the distributor housing and the spark plugs. Is this original?
Old 11-20-2023, 08:52 PM   #7
Joe K
Joe K's Avatar
High tension corona dissipative discharge points.
Similar in effect to the top point of the lightning rod on your barn.
I have used a metal paperclip when one of the brasses went missing.
Joe K
Old 11-20-2023, 10:07 PM   #8
Ray in La Mesa
It's not original but it works, it will bite you even when the engine isn't running! I have it on the #1 spark plug in my 86,000 mile '28 roadster pickup just to make people smile.
Ray in La Mesa is offline   Reply With Quote
