Old 11-12-2023, 09:52 AM   #1
Tudie 36
Tudie 36's Avatar
Default 1936 starter button HOT!
Took Tudie out today after replacing fuel pump. She ran really good, just went about 5 miles and came back and parked in garage. Took her out about two hours later, made it about 3 miles she started to stumble then shut off. Trying to restart found that the floor button was red hot. Had her towed home. I replaced the starter button about 6 months ago, noticed one of the posts is not straight and whole post spins. She had been turning over slow when starting lately. Ordered one that looks more original. Anything besides starter button that could have been damaged? Thanks, Greg
Tudie 36 is offline   Reply With Quote
Old 11-12-2023, 10:11 AM   #2
sugarmaker
sugarmaker's Avatar
Default Re: 1936 starter button HOT!
Greg,
Not sure on these. But had a old Falcon with red hot dimmer. Floor had rotted out and did not have a ground.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 11-12-2023, 10:21 AM   #3
Steve in Denver
Steve in Denver's Avatar
My ignition switch on my '36 was too hot to touch, turned out to be some looose wires.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 11-12-2023, 10:31 AM   #4
Tudie 36
Tudie 36's Avatar
It did have a loose connection, I thought I had every tool I needed for roadside adjustments but, 1/2 socket for some reason I left off. real hard to get a box wrench to that area. anyone know why it would have shut the car down? Coil maybe?
Old 11-12-2023, 10:36 AM   #5
Kube
Super Moderator
Kube's Avatar
I had been advised late last year by a very well respected '36 guy that the repop buttons are crap.
Source a NOS switch.
Old 11-12-2023, 10:43 AM   #6
FortyNiner
FortyNiner's Avatar
The quality isn't any better for the 46-48 versions.
Old 11-12-2023, 10:58 AM   #7
Planojc
Planojc's Avatar
The repo's are so bad that I changed over to a solenoid with a push button.
Planojc is offline   Reply With Quote
Old 11-12-2023, 11:28 AM   #8
TJ
TJ's Avatar
Those repo switches are junk. As advised look for a NOS one or a known brand NOSR one.
Old 11-12-2023, 01:33 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Use new nuts and washers , rusty ones will make for bad connections, and check the terminal ends on the wires, some cables have cheap steel ends that get internal connection problems (use magnet)
Old 11-13-2023, 07:10 PM   #10
mcflash
Test your voltage regulator. It's a remote possibility that the points can fuse.
mcflash is offline   Reply With Quote
Old 11-14-2023, 10:56 AM   #11
Karl Wescott
Karl Wescott's Avatar
OK, some basic troubleshooting here. If the floor switch is red hot electric energy is flowing through it, and where there is resistance you get heat. You have a partially shorted out switch. The switch should ONLY be making contact when you are engaging the starter. The reason the car quit is all the battery/generator energy was sucked out of the system to heat the switch.
The floor switch has nothing to do with the ignition or any other circuit than Battery-Switch-Starter. Because of the high amperage of the starter this is a heavy duty switch. This is why on later (1937 on) there was a solenoid (heavy duty switch controlled triggered by a low amperage signal).
This situation could easily have progressed to a fire. If the floor switch gets hot the battery needs to be disconnected NOW! If the motor still runs the generator also needs to be disconnected NOW! There is no fuse protection. Expect arcing when the battery (and generator) is disconnected as there is high current flow. Gloves and face protection would be a very good idea.
Karl Wescott is offline   Reply With Quote
Old 11-14-2023, 11:09 AM   #12
Automotive Stud
Automotive Stud's Avatar
Originally Posted by sugarmaker View Post
Greg,
Regards,
Chris and Cheryl
Dimmer switch shouldn't be grounding to the floor.
Automotive Stud is offline   Reply With Quote
Old 11-17-2023, 07:39 AM   #13
Tudie 36
Tudie 36's Avatar
Thanks, for this answer. I disconnected battery roadside, new button will be here today. Hope I didn’t do something stupid to cause this, like resting my foot on the button. Greg
Old 11-17-2023, 10:38 AM   #14
sugarmaker
sugarmaker's Avatar
Probably why I am not good at electrical stuff!
Thanks for the clarification.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
1966 Ford F100
Some Cub Cadets
Old 09-11-2025, 02:36 PM   #15
azlkk
azlkk's Avatar
I’m seeing around 0.2 ohm resistance across the original 90 year old starter switch. Is this normal?
'35 5 Window Deluxe Coupe w/radio- wife's uncle purchased new
azlkk is offline   Reply With Quote
Old 09-11-2025, 05:56 PM   #16
collinrestores
collinrestores's Avatar
Those floor switches were not Ford's finest moment. There's about an eighth of an inch between you and the battery exploding under your feet at all times. I'm planning on upgrading mine with a solenoid.
collinrestores is offline   Reply With Quote
Old 09-11-2025, 07:23 PM   #17
1942deluxe
1942deluxe's Avatar
100% agree. Ended up hunting down NOS ones for my 42,46 and 48 cars.
