Old 10-25-2023, 11:08 AM   #4
Jim Brierley
Default Re: Please Help with Flywheel Decision
Originally Posted by BRENT in 10-uh-C View Post
The first question I would have is, was the Model-B flywheel balanced to the rest of your engine? If so, how do you plan to rebalance a new flywheel assy. to your present rotating assembly?
FWIW, you will likely find the present flywheel assembly will be fine with the cam that your engine has unless it is a brand new cam. It has been my experiences that if yours is a reground camshaft, they do not produce the same low-end torque as what the IB330 camshaft does. If so, the heavier flywheel is not going to be of much advantage anyway.
4 cyl. engines are not balance as a unit, each piece is balanced separately.
