Old 10-02-2023, 08:16 PM   #1
[email protected]
k_dodd@swbell.net's Avatar
Default Low Beam Light Switch won't stay in position
When I'm driving with the light switch selector 1 click over (low beams) it keeps moving and shutting the lights off. When I move it to the 2nd click over (high beams) it will stay in position. It is very annoying having to hold the switch selector when driving to avoid blinding other drivers. Plus I just like things to work correctly! Suggestions on how to fix this? I know that horn rods and switches can be cantankerous. I want to find out suggestions on WHAT TO DO and WHAT NOT TO DO! Any help is appreciated.
Kevin
Essex, CT
k_dodd@swbell.net is offline   Reply With Quote
Old 10-02-2023, 11:37 PM   #2
Richard Knight
Default Re: Low Beam Light Switch won't stay in position
Kevin you might be able remove the bail and drop the switch down, undue the clip then pull the switch and horn rod up some and lubricate the bushing.that sits in the end of the tube. That might free it up.
Richard Knight is offline   Reply With Quote
Old 10-03-2023, 12:07 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
Often times when there is a problem as you describe, the light switch rod bushing at the top of the steering column may be missing or worn/damaged. https://www.snydersantiqueauto.com/p...7840&cat=41749
Old 10-03-2023, 10:54 AM   #4
[email protected]
What is preferred for lube--grease? light oil? heavier oil?
Kevin
Essex, CT
Old 10-03-2023, 11:10 AM   #5
JayJay
Or the light switch rod may be bent. The light switch rod goes down the middle of the steering column, and it doesn't take much to have it scrape along the walls and catch.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 10-03-2023, 11:38 AM   #6
Phil Brown
Phil Brown's Avatar
Sometimes the switch rubs on the steering wheel where it is recessed into the wheel. You can check it for clearance with a small piece of paper inserted between the switch and wheel to see if it gets tight. If it does slide the switch up a few inches and a little hand work with some sandpaper on the wheel recess should give you a bit of clearance
Phil Brown is offline   Reply With Quote
Old 10-04-2023, 04:50 AM   #7
Bruce of MN
Bruce of MN's Avatar
My horn rod had a squared off section just under the top that rubbed. My friend turned it down and I filed it round some more. That and a new bushing made my switch stay in place while turning the wheel. Of course, with my Coupe, it meant having to take the pitman arm off and unbolt the steering box.
Old 10-24-2023, 03:02 PM   #8
tucan31
I had a similar issue, the small copper light switch rod bushing on the horn rod was missing
tucan31 is offline   Reply With Quote
Old 10-25-2023, 12:42 AM   #9
MilwaukeeMike
MilwaukeeMike's Avatar
I had this problem during a rebuild that had a thread repair that altered clearance. I got two thin mylar washers with a drop if turbine oil between them. No more problem.
MilwaukeeMike is offline   Reply With Quote
