Old 10-07-2023, 03:29 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default Coil conversion kit install
Where does the condenser mount, to one of the 3 screws that mount the adapter plate to the distributor? The drawing shows it mounted vertically but there’s no provision for that.
Does it mount to the same terminal lug as the wire??
Tim Carlig
dean333 is offline   Reply With Quote
Old 10-07-2023, 04:07 PM   #2
Brian
Brian's Avatar
Default Re: Coil conversion kit install
yes, and the short wire goes to the terminal with the pigtail. as does the wire [not the HT lead] from the coil. Actually, you can mount the condenser up on the coil if you like, as long as the body of the condenser is grounded, and the short lead connects to the wire from coil to distributor. mounted there allows it to be in a cooler location and is more accessible
Old 10-07-2023, 04:14 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
They drew it "mounted vertically" because the view of the drawing was not well-thought out initially. Rotate the condenser (bracket) 90º from the position shown in the drawing and be done with it! Essentially, mount it to a GROUNDED surface.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 10-07-2023, 05:51 PM   #4
petehoovie
petehoovie's Avatar
Old 10-07-2023, 06:39 PM   #5
dean333
dean333's Avatar
I mounted the condenser on the coil per Brian’s suggestion.
Tim Carlig
Old 10-09-2023, 12:11 PM   #6
35fordtn
35fordtn's Avatar
Unless you bought the adapter from us, trash the condenser and run a FD72 condenser. Trust me on this one......
Old 10-09-2023, 03:33 PM   #7
dean333
dean333's Avatar
The conversion kit was in a Dennis Carpenter bag.
Tim Carlig
Old 10-09-2023, 03:38 PM   #8
dean333
dean333's Avatar
This one? It says it’s a Standard Brand.
Tim Carlig
Old 10-09-2023, 03:49 PM   #9
Kens 36
Kens 36's Avatar
Tim,
You need to trust Michael on this.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 10-09-2023, 04:59 PM   #10
dean333
dean333's Avatar
I will Ken, just want to be sure to get the correct one.
Tim Carlig
Old 10-09-2023, 06:22 PM   #11
35fordtn
35fordtn's Avatar
Yes that’s the correct one
Old 10-11-2023, 08:57 AM   #12
corvette8n
corvette8n's Avatar
Here’s my before and after, I had Skip rebuild a coil I picked up at a swap meet and used a condenser from Tubman.
Old 10-11-2023, 10:33 AM   #13
Seth Swoboda
Seth Swoboda's Avatar
I much perfer the skip rebuilt coil in your after picture to that ugly conversion kit.
Old 10-11-2023, 11:08 AM   #14
petehoovie
petehoovie's Avatar
Old 10-11-2023, 11:59 AM   #15
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Second with 3rd gen those kit condensors are junk !!!! Suggest tun man (awesum unit) or a rr175 napa unit ......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-11-2023, 03:08 PM   #16
dean333
dean333's Avatar
I ordered what Mike recommended.
Tim Carlig
Old 10-16-2023, 03:18 PM   #17
tubman
tubman's Avatar
This has been bothering me for days, so I just have to post about it. While I thank "corvette8n" and "petehoovie" for giving my condensers some exposure, I have to say I am quite embarrassed about the appearance of the early versions. The one shown was sold right after I decided to sell them to others and has my old style bottoms (which, in a word, were quite crude).
I have to say I agree with Seth that a much prefer that distributor with a "Skip's Coil" because it also hides the deficiencies of the condenser. Here are a couple of pictures of how I do it now.
Old 10-16-2023, 05:15 PM   #18
JayChicago
JayChicago's Avatar
99% of us never noticed the “deficiency” in your older style can. Looks good to me.
And they work great!
JayChicago is online now   Reply With Quote
