Old 10-04-2023, 08:00 AM   #1
Juergen
Default Re: 40 Ford Ignition Woes
You can eliminate the cap/rotor by checking the output of the coil. No spark there (along with no spark at a plug) says it is not a cap/rotor problem.
You have 6.2 volts at the coil. What do you have at the points side. Steady 0 would imply that the points stay closed, while 6.2 volts would imply that the points remain open. Assuming you have an analog meter, a slow crank speed should show some needle movement that the points are opening and closing.
Juergen is offline   Reply With Quote
Old 10-04-2023, 10:47 AM   #2
philipswanson
I'll check that next with my old Simpson analog meter. Thanks. Points are new and set up on a Sun machine but still could be the problem.
philipswanson is offline   Reply With Quote
