Old 09-25-2023, 02:49 PM   #1
philipswanson
Default 40 Ford Ignition Woes
My son bought a 40 Ford truck with a 59A flathead. It wasn't running when he got it. I put new points in it on my Sun machine and set the dwell. It started right up and ran well. We went for a ride and all ran strong. We drove about 5 miles and all of a sudden it died. No spark condition. We called AAA and got a tow home. He changed the coil and it started right up again. He took it for another ride days later and the same thing happened. Had to get it towed home again. What do you experts think is causing this?? Help please.
philipswanson is offline   Reply With Quote
Old 09-25-2023, 02:55 PM   #2
Mart
Mart's Avatar
Default Re: 40 Ford Ignition Woes
Crab or helmet?
I have had problems with the HT side of the ignition. Cap and rotor can all fail under load, and run fine again until hot and loaded again. Have any spares you can swap on?
Old 09-25-2023, 03:27 PM   #3
marko39
Check to see if the balist resistor is not bypassed as this can fry a coil .
marko39 is offline   Reply With Quote
Old 09-25-2023, 03:51 PM   #4
aussie merc
aussie merc's Avatar
with Mart crab / helmet or aftermarket also 6v/12v No such thing as to much information ??
aussie merc is offline   Reply With Quote
Old 09-25-2023, 10:23 PM   #5
ford38v8
ford38v8's Avatar
He changed the coil? More info please. Another coil from the cardboard box in the trunk?
Alan
Old 09-26-2023, 05:50 AM   #6
Terry,OH
Terry,OH's Avatar
There are several items that with heat can go bad but when cold are OK. The ones mentioned above plus the ignition condenser.
Old 09-26-2023, 01:09 PM   #7
Fritz
Fritz's Avatar
I put a Pertronix unit in a crab distributor on my engine because these reproduction parts are so terrible.
But, if I were doing a stock ignition all over again, I’d buy a coil from Skip Haney and a condenser from Tubman.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 09-26-2023, 03:22 PM   #8
philipswanson
It's a crab distributor. I think the resistor has been bypassed. I will have my son check it out tonight. Will let you know what we find. Thanks!
Old 09-26-2023, 09:15 PM   #9
SoCalCoupe
SoCalCoupe's Avatar
Did that with my helmet distributor. VERY SATISFIED! Car runs really strong and reliable. I'd be confident using it as a daily driver. Bought 2 each so I'd have spares. Also bought NOS resistors and points on evilBay for spares.
SoCalCoupe is offline   Reply With Quote
Old 09-26-2023, 09:44 PM   #10
JK1934
JK1934's Avatar
something worth checking is how the points fit on the pivot post, I just had one set of points lock up when it got hot so the 1 point was locked open so the distributor had no spark, was ok & tested good when it was cold but after driving for an hour or so the 1 set of points locked up, I have just drilled it out to give more clearance
JK1934 is offline   Reply With Quote
Old 09-27-2023, 11:57 AM   #11
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Condensor condensor condensor
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-27-2023, 06:52 PM   #12
philipswanson
Where were you buying your condensers?
Old 10-01-2023, 10:20 AM   #13
philipswanson
Changed the condenser, same thing happened and needed another tow.
Old 10-01-2023, 12:57 PM   #14
philipswanson
The resistor is bypassed but we are running a 6v coil that doesn't require a resistor from Napa.
Old 10-01-2023, 01:08 PM   #15
Juergen
The first thing I check when a car just stops as check if an ignition or gas problem. Take off the air cleaner and work the throttle to see if the accelerator pump squirts out gas. If so fuel is not a problem. Then pull a wire and hold it close to ground as you try to start. You should have a hot blue spark. With a crab distributor you have an external coil. So check the output of the coil with the spark test. If still nothing you know it is in the ignition upstream of the coil. Check the input voltage at the coil. If not there keep going back.
Juergen is offline   Reply With Quote
Old 10-01-2023, 02:24 PM   #16
petehoovie
petehoovie's Avatar
Flaky ignition switch...
Old 10-01-2023, 06:23 PM   #17
philipswanson
We checked for a fuel problem and getting a squirt. No spark though. Next time we take it out, I am bringing a hotwire and a multimeter. Thanks!
Old 10-01-2023, 11:25 PM   #18
aussie merc
just wondering where is the coil mounted had nothing but drama when i went back to a crab turns out the coil was overheating when mounted on the eng moved it to the inner guard problems solved you couldn't touch the coil it was that hot but now gets warm but you can hang on to it
Old 10-03-2023, 06:01 PM   #19
philipswanson
We worked on it again last night. Put another new condenser and coil from Napa on it and as usual it started right up. We drove it about 50 feet and it died again. Pulled a plug and checked for spark and none. Turned key on again and checked voltage on the - side of the coil. 6.2 volts present. In my estimation, it has to be the cap, rotor or distributor. What else can it be?
Old 10-03-2023, 07:08 PM   #20
Ken/Alabama
Ken/Alabama's Avatar
Check the ignition switch at the steering column. Take it off and check the contacts. They get corroded and burned and cause a high resistance.
