I will not bore you with all that I went through with this engine but here is my question. I obtained this engine with a 4" crank, racing pistons, and a 400jr cam. No heads or intake. I put a stock intake and stock 8BA heads on it and promptly bent 15 out of 16 valves. It would sort of run on 5 cylinders. After taking all apart, I find I have sbc valves. The exhaust are 1.5" and the intakes are 1.6". After getting new valves and different heads with more valve pocket clearance, and doing a little modification it is again running. It runs good but I don't like the sound out the exhaust. With the other stuff different to the engine, can I just put in a stock cam? This car will never do more than cruise the streets of town. I forgot, it has adjustable lifters.
does it have the exhaust dividers between 2/3 and 6/7? if not put them in and see if that changes the sound. it seems like you have exhaust valve overlap with such a high lift cam
If the lope in the exhaust at idle and low speeds is what you don't care for, then yes...install a stock cam. It'll work fine and will idle smooth. The adjustable lifters should accommodate the stock cam.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
"With the other stuff different to the engine, can I just put in a stock cam? "
Read this BEFORE you decide to install baffles. https://www.fordbarn.com/forum/showthread.php?t=51343 If you need baffles, I have a brand new set I never used. I sent you a PM. Last edited by 19Fordy; 09-30-2023 at 02:09 PM. |
The 400jr is a very good track cam, but it's long duration make it a poor street cam. But the sound is great. Ran one for a few years, worked quite well. Replaced it with the Erson D-410
Gramps |
I did and I like everything about it. |
I agree, ^^^ merc cam is a good stock unit. A little more low end torque as the automatics were coming in, and the merc was a heavy car. A local cam grinder near me
had a bin full of them for me. Barry Cam , Plato Minnesota |
Back in the day, when pulling into a drive-in, Hot rodders would pull out the choke to achieve that lumpy sound. It made it sound like they had a hot cam.
Thanks for all the help. I think I will go with a stock can rather than baffels. Since this is in a 48 Mercury, I will try to find a Merc cam.
al |
'48 Mercury? I thought this thread was about an 8BA.
If it truly is a '59A, then Ford or Merc cams are the same as far as I know.
Isn't that be Berry Cam
Ronnie |
Yes it is an 8BA engine, but I have installed it in a 48 merc
#13 |
8CM in my '41 Merc as well. It's a good swap. Mine has the 8CM Merc cam and is perfect for the way I use it. Strong but good manners.
#14 |
I really don't think you could feel the difference between between any of the various 8bA style cams. Compression and carburetion. also have an efect on performance. Personaly I like the EAB cam, But it's the only stock cam I ever used.
G |
| Thread Tools | |
| Display Modes | |
