Old 09-12-2023, 05:16 PM   #1
spdway1
spdway1's Avatar
Default 1/2 Ton?
Is a regular standard Model A truck chassis considered a half ton?
spdway1 is offline   Reply With Quote
Old 09-12-2023, 07:07 PM   #2
Gary WA
Gary WA's Avatar
Default Re: 1/2 Ton?
I'm saying yes, Model A Chassis is 1680 lbs,Model AA with wheels dual is 2847lbs
www.whidbeymodelaclub.com
Old 09-12-2023, 10:35 PM   #3
spdway1
spdway1's Avatar
The 30 AA duel wheel truck is advertised as a 1.5-ton truck
Old 09-12-2023, 11:31 PM   #4
Dave Mellor NJ
I have heard of the standard pickup being referred to as a 1/4 ton
Dave Mellor NJ is offline   Reply With Quote
Old 09-13-2023, 07:24 AM   #5
1931stdcoupe
Doesn't 1/2 ton or 1/4 ton refer to the payload the vehicle is capable of carrying, not the weight of the vehicle?
1931stdcoupe is offline   Reply With Quote
Old 09-13-2023, 08:07 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, the Model-A Pickup was listed as a ¼-Ton. Think about the rear spring capacity which is the limiting factor on weight capacity.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-13-2023, 10:58 AM   #7
Cape Codder
Cape Codder's Avatar
My "AA" has helper springs in the rear attached under the standard springs, curved the opposite way. Also, the front spring has a helper spring attached under it as the rear! When I first purchased the truck I read that with these added springs it is rated as a 2 1/2 ton.
Anyone know for sure if the above info is correct?
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 09-13-2023, 11:01 AM   #8
Bob C
What is the load capacity of a Roadster?
Old 09-13-2023, 11:27 AM   #9
ronn
a pretty fat wife and a skinny owner...................
Old 09-13-2023, 12:27 PM   #10
mcgarrett
I worked for a few years with a company that did truck commercial truck up-fitting and frame modification for all sorts of commercial duty applications for light duty, medium duty and heavy duty, body installations, cranes, etc. so I saw firsthand the extra engineering that sometimes had to be done to make certain trucks fit for the service they were needed for.
It's not just the addition of helper springs that would automatically render the Model A pickup worthy of carrying an appreciable amount of excess weight. They can only do so much if you are planning to burden the Model A frame/suspension system with more weight than it was designed to carry. Don't forget to give strong consideration to the other suspension components in play that are directly affected by stresses and loads beyond designed limits such as the frame, axle shafts, axle tubes, axle bearings, wheels & tires, brakes, etc. With the Model A pickup bed overhang bias being more to the rear of the center of the rear axle, improper load distribution can have a dangerous effect on braking and handling and going around turns when loaded. The Model A pickup might be able to handle the extra loading you speak of while sitting still, but going down the road is a completely different matter. I urge you to be very careful here.
Old 09-14-2023, 09:44 AM   #11
ddweave
ddweave's Avatar
My '31 pickup has helper springs. Have you seen these before?
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 09-14-2023, 01:35 PM   #12
spdway1
spdway1's Avatar
Yes, mine even has a set on the front too!
