Old 08-03-2023, 06:21 PM   #1
busmania
busmania's Avatar
Default Can I hone Flathead lifter bores?
I got my block back from the machine shop. It looks like there is a very slight amount of surface rust in the lifter bores. Should I home this with a wheel cylinder hone? Or will that remove too much material?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 08-03-2023, 06:26 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Can I hone Flathead lifter bores?
Take a rag and wd40- or anything else- to it, I'll bet it goes away.
Karl
Karl Wolf is offline   Reply With Quote
Old 08-03-2023, 06:39 PM   #3
Ronnie
Ronnie's Avatar
^^^^ Yup
Ronnie
Ronnie is offline   Reply With Quote
Old 08-03-2023, 08:54 PM   #4
alanwoodieman
round brass wire brush and any lubricant
Old 08-03-2023, 10:33 PM   #5
ford38v8
ford38v8's Avatar
Why bother doing anything about it? The lifters will make short work of any surface rust before the thermostats even open up.
Alan
ford38v8 is online now   Reply With Quote
Old 08-03-2023, 10:42 PM   #6
tubman
tubman's Avatar
This is probably true, but I would cringe at putting a lifter in a visibly rusty bore. I'll bet most folks are like that, too.
Old 08-03-2023, 10:55 PM   #7
cadillac512
cadillac512's Avatar
A wheel cyl hone will not remove too much material. You do want a nice clean smooth surface to make sure the lifters rotate freely when they operate, so do what it takes to achieve that. Cleanup after honing is of course of utmost importance.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-04-2023, 07:22 AM   #8
busmania
busmania's Avatar
I ended up running the hone for a very short time through each bore. Cleaning didn’t do enough for me plus but I honed it moreso to make sure there wasn’t a sharp edge from drilling the holes for the adjustable lifters. I maybe did 3 seconds per hole. Just enough to ensure it’s smooth but not really remove any material. I then washed the block for final prep for about an hour. Not sure it could be any cleaner! Thanks y’all.
Old 08-04-2023, 09:54 AM   #9
cadillac512
That's perfect. Well done .
Old 08-04-2023, 10:23 AM   #10
Ol' Ron
Ol' Ron's Avatar
After I drill all my lifter bores for the lifter adjustment stop. i run a brake cylinder hone thrugh the lifter bore nabd the guide bor to clean them and remove any chips from drilling,
This is another reaon I like to run a 95
Old 08-04-2023, 02:59 PM   #11
Tim Ayers
3M makes these great Scotch Brite pads that are like a flowers or balls. They go on a standard spindle so you can get into various depths. They are great for they remove rust or small burrs but don't remove material.
Old 08-04-2023, 08:32 PM   #12
38 coupe
38 coupe's Avatar
Originally Posted by Ol' Ron View Post
This is another reason I like to run a 95
Ron, I have to ask, what is the 95? I'm not used to that term.
Old 08-06-2023, 10:22 AM   #13
Ol' Ron
Ol' Ron's Avatar
I thought I wrot 95% oil filter. Just getting old, I guess
G
Old 08-06-2023, 11:34 AM   #14
38 coupe
38 coupe's Avatar
Thank you for the clarification.
