Old 06-19-2023, 08:16 PM   #1
cvicky
cvicky's Avatar
Default y block ticking
272 started making what i thought was a manifold leek, so i poured tranny oil down the carb and the smoke exposed the leek at exhaust manifold wich is now fixed .
noise still there
i can rev engine 3500 rpm in neutral , NO NOISE then soon as i let clutch out and put motor under load noise appears and is obvious when acccellerating
cvicky is offline   Reply With Quote
Old 06-19-2023, 10:01 PM   #2
fordor41
fordor41's Avatar
Default Re: y block ticking
spark knock? timing?
fordor41 is offline   Reply With Quote
Old 06-19-2023, 10:17 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
It's probably not the engine. I would suspect one of the u-joints or transmission. Do you have the bottom flywheel cover installed on the bellhousing? It's not a good idea to drive without that because a rock can fly up in there and get kicked around by the flywheel.
Old 06-20-2023, 06:59 AM   #4
ventport
How are the motor mounts? If under load and the motor rocks, it can open up an exhaust leak that is not there when not under load.
ventport is offline   Reply With Quote
Old 06-20-2023, 10:55 AM   #5
cvicky
cvicky's Avatar
it was at 12* i pulled it back to 6* still ticking
Old 06-20-2023, 10:58 AM   #6
cvicky
cvicky's Avatar
fly wheel cover has been off for 7 yrs
u joints seem ok
next is motor mounts ...
Old 06-20-2023, 06:16 PM   #7
34pickup
34pickup's Avatar
I once had a tick on my 56 292 that finally turned out to be one of the rocker arm shaft mounting bolts loosened up allowing too much clearance on the rocker arm assembly. Listen at the valve cover to see if that can be eliminated.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 06-20-2023, 08:28 PM   #8
Daves55Sedan
I would think you would hear it at idle speed also if either a loose rocker shaft mounting bolt or a woefully loose adjusted rocker arm. He said it makes no noise at idle.
Old 06-20-2023, 09:30 PM   #9
cvicky
cvicky's Avatar
yes and i even blocked the wheels with emergency brake on and loaded the motor " no ticking" only while driving
Old 06-21-2023, 09:08 AM   #10
cvicky
cvicky's Avatar
i'll check rocker shafts
Old 06-21-2023, 03:11 PM   #11
Ole Don
Ole Don's Avatar
Only when driving takes the noise to behind the flywheel. Those U joints may seem OK, but I would bet the price of a U joint that one is bad.
Ole Don is offline   Reply With Quote
Old 06-21-2023, 04:01 PM   #12
cvicky
cvicky's Avatar
ok ill yank the drive shaft
stay tunned
Old 06-21-2023, 10:40 PM   #13
Daves55Sedan
Tell ya what. Leave that flywheel bottom cover off and drive down a few dusty roads. That flywheel acts as a fan blowing dust right at the starter drive. It'll be no time and your starter drive will be stuck in the disengaged position.
Old 06-22-2023, 06:48 AM   #14
cadillac512
cadillac512's Avatar
Put car on jackstands under the rear axle. Run it in gear, accelerate while applying brakes to load the engine. Have a helper listen under hood (or elsewhere) to locate the noise.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-22-2023, 08:32 AM   #15
cvicky
cvicky's Avatar
I’ll put cover on when I’m sure rear main is not leaking on my refreshed 272
Off to check u joints
Old 06-22-2023, 11:56 AM   #16
cvicky
cvicky's Avatar
drive shaft is off
everything is free ,smooth and no slop so i greased it now reinstalling
so now its to run car on jack stands
or check rocker shaft and make sure its tight to the head ...
Old 06-22-2023, 04:33 PM   #17
cvicky
cvicky's Avatar
drive shaft is ok
rocker shaft and valve lash is ok
i'll have to get help to run it on stands
Old 06-22-2023, 06:40 PM   #18
Alaska Jim
Alaska Jim's Avatar
Are you sure it is not "pinging", caused by poor fuel octane, or incorrect ignition timing? This only happens under the conditions you described.
Alaska Jim is offline   Reply With Quote
Old 06-22-2023, 08:56 PM   #19
cvicky
cvicky's Avatar
sounds like a manifold leak , i'll go at it again tommorow
i'm at 6* maybe pull a bit more timing out
i only use premium pump and i've put a few tanks recently
Old 06-22-2023, 10:18 PM   #20
fordor41
fordor41's Avatar
have a manual choke? if not set choke part way closed and retry. If you don't hear the noise it's running lean.
