Old 06-07-2023, 05:28 PM   #1
jgriffin
jgriffin's Avatar
Default Tillotson carburetor question
While refreshing a Tillotson Carb and putting it back together I found that the upper pot metal piece is not flat. So when I am putting the 3 screws back together there is a gap large enough to where the gasket will not seal. Any suggestions on how to correct this? If it was the lower piece it looks like it would be easy to sand down flat.
Thanks in advance for any insight!!
jgriffin is offline   Reply With Quote
Old 06-07-2023, 06:18 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Tillotson carburetor question
A Good file?
www.whidbeymodelaclub.com
Old 06-07-2023, 08:14 PM   #3
bobbader
Filing is a bad option here since the lower venturi is part of the upper casting. If you start filing by going "around" the venturi, you'll do more damage. Depending on how bad the warpage is, a double gasket may work. If not, you have to be very crafty in "bending" the warp back down. This is a delicate procedure, but it can yield success with lots of patience. I suggest you do a Fordbarn Search for more information on this subject as there are a couple of different ways to fix this problem and the explanations are long.
bobbader is offline   Reply With Quote
Old 06-08-2023, 06:17 PM   #4
mrtexas
mrtexas's Avatar
Whack it good with a rubber or plastic hammer. https://mrtexasmodela.weebly.com/restoretilly.html
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 06-08-2023, 08:15 PM   #5
mcgarrett
Easier to find another carburetor. A Marvel is an excellent choice too.
Old 06-08-2023, 09:00 PM   #6
burner31
burner31's Avatar
Use the oven method, works great
when you are done heating let it cool slowly in the oven, ready to go in the morning
Keith
Shawnee OK
'31 SW 160-B
Old 06-08-2023, 09:45 PM   #7
vic
Bolt the two halves together
Straddle the two halves with a G cramp
Apply heat with a propane torch to top half(not too much)
Gently tighten the G cramp until gap disappears.
I've done several this way with no problems.
Vic , New Zealand
vic is offline   Reply With Quote
Old 06-09-2023, 09:44 AM   #8
jgriffin
jgriffin's Avatar
Thanks again for all the good information! I will give her a go
Old 06-14-2023, 10:07 AM   #9
Alwaysamopar74
I used a arbor press on my top. I just set up some little blocks and used the press to push on the middle of the carb. Little at a time with patience. Used a straight edge to verify. And test fitted to body of carb. Shouldn't taken pictures but I didn't. I know a lot of these carbs are bent from people over tightening them over the years.
Alwaysamopar74 is offline   Reply With Quote
Old 06-14-2023, 01:28 PM   #10
Redbird
Redbird's Avatar
Kitchen oven worked for me. A couple C-clamps @ 250 degrees. Tighten as you go.
Redbird is offline   Reply With Quote
