#41 | |
Enjoy your car. Wait till a nice warm spring day. Tell us how it works out. Haze Gray and Underway. |
#42 |
Yeah hobby, it is fun, repairs with a 5# hammer are easy. slowly getting her back to how she rolled off the line, within reason. Not going for the Blue-Ribbon award. Just glad I got one and can have fun with it.
#43 |
Won mine as a door prize at a car show, put them on...love them
#44 |
I have a fan shroud, 4 blade aftermarket fan and pans with a double venturi carb, never overheated and she purrrrrrrrrrrrs like a kitten.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
#45 |
Have been lucky for several yrs. with pans. No Problems yet and the look is great. Also, easy to drain water and wipe any oil from the steering box.
#46 |
Could you please relay any if not all of these benefit of running splash pans? Thanks. Learning as I go. |
#47 |
See post #5. Engine pans reduce dust infiltration into the engine bay, which can help if you're not using an air filter. They direct the flow of oil or coolant when you're doing things like draining the radiator or removing the valve cover, so it makes cleanup easier. They are thought to improve the performance of the cooling system by forcing air to come through the radiator and out the louvers, rather than allowing air to move in and out randomly through the bottom of the engine bay; however, this is mostly conjecture and anecdote, it hasn't been proven and we don't have documentation from the OEM stating that this is the intent.
#48 |
i use them
#49 |
One benefit no one has mentioned, they are great for storing stuff,
I have a little box on mine on the left side, to store stuff, oil bottle ,rainex,etc Lawrie |
#50 |
I use them because they were on my car when I bought it. I like the look.
#51 |
I'm using them
#52 | |
![]() Mine saved my K&N air filter from getting lost... |
#53 |
In a November 1929 service bulletin there is a design change to help with the tabs breaking. Find the later ones to replace ones that broke. P.393.
It's not the destination ,it's the journey . |
| Thread Tools | |
| Display Modes | |
