Old 02-02-2023, 10:14 AM   #41
WHN
Default Re: How nat of you are using engine/motor pans?
Originally Posted by Canton_Model_A's View Post
just ordered my 2 Black powder coated ones from Snyders, should be here tomorrow, but lots of luck me puttin' them in anytime soon. the Snow has to go away first and get a tad bit warmer.
This is a Hobby, not a job.
Enjoy your car. Wait till a nice warm spring day.
Tell us how it works out.
Haze Gray and Underway.
Old 02-02-2023, 11:32 AM   #42
Canton_Model_A's
Canton_Model_A's's Avatar
Yeah hobby, it is fun, repairs with a 5# hammer are easy. slowly getting her back to how she rolled off the line, within reason. Not going for the Blue-Ribbon award. Just glad I got one and can have fun with it.
Canton_Model_A's is offline   Reply With Quote
Old 02-03-2023, 05:26 PM   #43
burner31
burner31's Avatar
Won mine as a door prize at a car show, put them on...love them
Keith
Shawnee OK
'31 SW 160-B
Old 02-04-2023, 11:55 PM   #44
al's28/33
al's28/33's Avatar
I have a fan shroud, 4 blade aftermarket fan and pans with a double venturi carb, never overheated and she purrrrrrrrrrrrs like a kitten.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-05-2023, 10:41 AM   #45
vangogh
Have been lucky for several yrs. with pans. No Problems yet and the look is great. Also, easy to drain water and wipe any oil from the steering box.
vangogh is offline   Reply With Quote
Old 05-23-2023, 09:53 AM   #46
Ramman
alexiskai;2198860]The benefits of engine pans are well-understood.
Could you please relay any if not all of these benefit of running splash pans?
Thanks. Learning as I go.
Ramman is offline   Reply With Quote
Old 05-23-2023, 11:01 AM   #47
alexiskai
alexiskai's Avatar
See post #5. Engine pans reduce dust infiltration into the engine bay, which can help if you're not using an air filter. They direct the flow of oil or coolant when you're doing things like draining the radiator or removing the valve cover, so it makes cleanup easier. They are thought to improve the performance of the cooling system by forcing air to come through the radiator and out the louvers, rather than allowing air to move in and out randomly through the bottom of the engine bay; however, this is mostly conjecture and anecdote, it hasn't been proven and we don't have documentation from the OEM stating that this is the intent.
Old 05-23-2023, 02:17 PM   #48
Aretino
Aretino's Avatar
i use them
Aretino is offline   Reply With Quote
Old 05-23-2023, 04:24 PM   #49
Lawrie
Lawrie's Avatar
One benefit no one has mentioned, they are great for storing stuff,
I have a little box on mine on the left side, to store stuff, oil bottle ,rainex,etc
Lawrie
Old 05-23-2023, 05:09 PM   #50
29spcoupe
29spcoupe's Avatar
I use them because they were on my car when I bought it. I like the look.
29spcoupe is offline   Reply With Quote
Old 05-23-2023, 06:21 PM   #51
burner31
burner31's Avatar
I'm using them
Keith
Shawnee OK
'31 SW 160-B
Old 05-23-2023, 06:30 PM   #52
Y-Blockhead
Y-Blockhead's Avatar
Lawrie
You could wrap a burrito in foil and place it on the right side by the pipe to keep it warm.
Mine saved my K&N air filter from getting lost...
Old 05-28-2023, 01:53 PM   #53
stevemclark
stevemclark's Avatar
In a November 1929 service bulletin there is a design change to help with the tabs breaking. Find the later ones to replace ones that broke. P.393.
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
