Old 05-14-2023, 11:09 AM   #1
cadillac512
cadillac512's Avatar
Default Re: Recut domes in EAB heads
A followup to the recut dome EAB head installation on my 260" Merc. I've run a few tanks of gas through it now, and where it previously delivered 16.5-17 mpg I am now seeing 18-18.7 mpg. The extra torque from the compression increase really has made a difference.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-14-2023, 01:33 PM   #2
Zeke3
Zeke3's Avatar
Terry, thanks for the update.
Zeke3 is offline   Reply With Quote
Old 05-14-2023, 04:26 PM   #3
38 coupe
38 coupe's Avatar
Terry
Thank you for the update. I find this very interesting, and per my memory is consistent with other back-to-back reports of modifying stock heads. Using the big flathead compression ratio file you increased compression from approximately 6.8 to 7.7 which is about 12%. You measured about 10% improvement in fuel economy. That improvement in fuel economy must come directly from improved power at the same part throttle.
The amount of improvement is much more than the normal theoretical improvement in power for a compression bump. I suspect this is because the theoretical compression benefits are not taking into account the improved combustion chamber dynamics that can be had in our ancient design side valve motors.
